4agze engine light problems
Post Reply
Monsterbishi
Contact:
Post by Monsterbishi »
Then you probably have the wrong two wires jumpered, or the connection isin't good enough between them, in that case, jumper them at the ecu end of things.
If that doesn't work, then chances are your ecu could be failing.
--- Cut Here ---
'94 JDM Ford Mustang GT Coupe
joe(nz)
Post by joe(nz) »
JiNX wrote:jumper them at the ecu end of things.
Hey man, could you explain how to do this please? Cos im sure Ive jumperered the correct pins.
cheers.
Monsterbishi
Contact:
ok, what is your car, AE92, AW11? All that essentially needs to be done is trace the two diag wires back to the ecu and jumper them there, although you could start out by taking out your ecu, unscerwing it's lid and examing it for any leaking caps, etc.
If it's a AW11, I could probably meet up with you and you could try out my AFM ECU in your car to see if it does the same thing, I've got a MAP AE92 SC one around here somewhere...
--- Cut Here ---
joe(nz)
Post by joe(nz) »
Sorry should have said - its an AE101 GTZ. Is the ECU under the passenger seat?
Also I just rang Ilam Toyota and they want to charge me $68 (1 hours labour) just do the diagnostic check 8O ) screw that!
Monsterbishi
Contact:
Hmm, I'll have to pass on that question(have never looked at a 101 before), normally the ecu is bolted up under the dash somewhere...
--- Cut Here ---
Post Reply
