4agze maintainance q's
Postby Caveman » Tue Dec 21, 2004 11:53 pm
I forgot to ask what model car you have. Most 4AGZEs are distributorless and have twin coils. If so this cannot be your problem however from what you've said about the 'alloy thing perpendicular to the cams with the plug' it sounds like you have a distributor model. The distributor is usually plastic and has five plugs in it. 4 of these plugs connect to the spark plugs and one plugs into the ignition coil. If it only has 4 plugs, each going into the spark plugs you have a distributorless motor.
This leak is not hard to fix (from what i've heard, i've never done it).
AW11 Track Toy
Formerly known as 1998
Caveman
Postby CITIZEN » Wed Dec 22, 2004 6:40 am
yeah i thought they were distributorless. i know what a dizzy looks like, just thought it might be a little different to others. whatever it is, it has a bit of oil on it anyway so probably from the cam seal
its an afm gze btw
CITIZEN
