Caldina GTT 3sgte ignition system - how many ignitors?
Postby fivebob » Thu Dec 23, 2004 8:39 am
If it's the same as other Coil on Plug Toyotas, then it will have 4 seperate ignition triggers. However, as far as I can tell, either the ignitors are built into the coils, or it doesn't have any, cause there are no seperate ignitors in the loom that I can find.
Postby blitza » Fri Jan 07, 2005 5:01 pm
smc?
MAD Industries Limited
blitza
Postby TWSTD » Fri Jan 07, 2005 6:33 pm
indeed :-)
Just ascertaining exactly what i need to specify prior to ordering it in terms of the caldina ignition...
Click here!
TWSTD
Postby blitza » Fri Jan 07, 2005 10:56 pm
sorry, to me smc is sheet moulded composite, I'm not following the topic here......
blitza
Postby fivebob » Fri Jan 07, 2005 11:01 pm
blitza wrote:sorry, to me smc is sheet moulded composite, I'm not following the topic here......
SMC = Autronic ECU http://www.autronic.com/page_files/smc_kit.htm
Postby blitza » Fri Jan 07, 2005 11:05 pm
chur
blitza
