brake + reverse lights not going
Postby scope » Wed Jan 05, 2005 10:06 pm
pidge wrote:Check the grounding point - the wiring harness will have one wire that should be attached to the body of the car. Could be loose or rusted up.
where will this be? the tail/stop lights work when i have the headlights on so i figured it must be a problem with the switch but that leaves out the reverse lights, maybe the switch too
scope
