Inner tyre wear?
Postby pervert » Mon Dec 27, 2004 5:50 pm
GT4 20 wrote:
CozmoNz wrote:my fronts probbaly do too then :S describes why the bloody car wont sit still doing wheelspins. Yesterday, in carpark, FILLED with water *PISSING DOWN*, handbrake locked on as hard as i can pull, fully up, rev to 6, dump clutch and plant it, and it drags me across the car park :S.
And people wonder why the cops are so harsh on performance car owners :roll:
Exactly...thats not cool...
pervert
Postby Ae92typeX » Mon Dec 27, 2004 7:54 pm
you dont mention if you have lowered it or not also.- if it is than the camber will cause it to wear a little more. otherwise yea to the other reasons above.
Ae92typeX
Postby Hbomb » Mon Dec 27, 2004 8:18 pm
Nah I havent lowered it. I reduced the tyre pressure slightly, my bro reockoned I mite have been pumping it a bit too high. How do I check the camber adjustment?
I only really noticed it on the rear tyres
Peaks and Freaks
Hbomb
Postby Ae92typeX » Mon Dec 27, 2004 9:03 pm
just take it into an alignment place and get a 4 wheel alignment- if youve never had one may as well get it anyway. That will cost between 35-60 depending where you go. What pressure your tyres at? Although it does vary 28-30psi should be sweet.
Ae92typeX
Postby Mr Revhead » Mon Dec 27, 2004 9:45 pm
tell em to set the front at 1 deg negative, when they try and tell u they will wear, tell em to shut up and do it. it will transform the handling.
also fit a towbar, you will be amazed at the difference that will make in stifness
28-30 is a bit low. keep it between 32-36.
no higher, youll be amazed how hot tyres cab get. and with higher temps comes higher pressuere.
i run my ae101 on dunlop fm901s at 34-36 on the front and 32-34 at the rear. usually only run the higher pressures on road trips when its wet.
Postby RedMist » Tue Dec 28, 2004 7:30 am
1 degree negitive? Camber? Does the 101 have too much ackerman?
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby AirNZ » Tue Dec 28, 2004 8:33 am
would that negative 1 degree be the go for all fwd toyotas?
AirNZ
Postby Mr Revhead » Tue Dec 28, 2004 1:05 pm
no idea redmist. have not done any measuering or anything. all i know is my front is set to 1 degree and with the pressures i run and my driving style the tyres wear perfectly even and it handles so so so well.
set to factory spec it understeered badly. i even had it rechecked to make sure it had been set up properly.
not sound right to you?
airnz, dunno try it an see. i havnet played with any others.
you need a bit of negative anyway. positive is bad!
Postby THA SHZ » Wed Dec 29, 2004 11:37 pm
Inner tyre wear will mean one of two things either excessive negative camber or more than likely toe OUT not in .
If u want a wheel alignment gve me a holler sum time and levins and truenos don't have adjustable fornt camber unless u put in after market eccentric bolts to adjust camber 8)
THA SHZ
Postby Mr Revhead » Thu Dec 30, 2004 10:42 am
theres diff size bolts listed on the epc and carried by toyota 8)
Postby Al » Thu Dec 30, 2004 11:46 am
Mr Revhead wrote: in fact it was 18k on the front...
Thats a whole heap of kms, im lucky to get 10k out of my dunlop w10 rears :lol:
Al
Postby kingcorolla » Thu Dec 30, 2004 11:47 am
judging by your avatar, im not suprised! :lol:
1983 Carina AA63 4age
kingcorolla
Postby THA SHZ » Thu Dec 30, 2004 5:05 pm
Mr Revhead wrote:theres diff size bolts listed on the epc and carried by toyota 8)
They wood have to be eccentric bolts or they woodn't move the camber , but the levins and truenos don't come with them from factory. 8)
THA SHZ
Postby Spannergal » Thu Dec 30, 2004 5:18 pm
i'd say that he knows that given he owns one - think the point was that they're available if needed
Spannergal
Postby THA SHZ » Thu Dec 30, 2004 5:29 pm
Think i understood that one but trying to clarify for the person who originally wrote this so they understand k 8)
THA SHZ
Postby Mr Revhead » Thu Dec 30, 2004 7:18 pm
now now ppl no fighting over me! :lol:
as they come from the factory there is no real adjustment in the camber.
if you so wish you can get smaller dia bolts that allow some adjustment. they are only about $15 each irc
well worth it in my opinion 8)
Postby THA SHZ » Thu Dec 30, 2004 10:09 pm
Mr Revhead wrote:now now ppl no fighting over me! :lol:
Oh but i want u and ur goats :lol:
$15 - dam thats cheap the eccentrics that i get for most cars cost me more than that at autolign bloody robbers !
So yes i wood reckomend gettin these for your as they are esential for good wheel alignments . 8)
THA SHZ
Postby CozmoNz » Fri Dec 31, 2004 12:01 am
and they can be brought from where ^_^.
must now have since they have been said about on toyspeed... must.... grrrrrr
Rayne For President!
CozmoNz
Postby Spannergal » Fri Dec 31, 2004 9:09 am
Cozmo - Revhead works for Toyota in Nelson - the price he is quoting is likely what he can do them for - pm him if ya wanna know details
Spannergal
Postby Mr Revhead » Fri Dec 31, 2004 9:09 am
come get some shz :wink:
acutally they range from $8.30 to $11 plus gst rrp.
so pretty cheap for the gains you can get!
they are avail for most toyotas.
this doesnt apply to s/s though casue of the different layout. i think you need camber plates for them
Users browsing this forum: No registered users and 27 guests
