4agze questions
Postby Monsterbishi » Fri Dec 31, 2004 4:37 pm
I have my FPR hooked straight up, no worries there, but if you eliminate the TB coolant lines, you'll need to modify the waxstat setup so that the idle doesn't run high and bounce all the time.
--- Cut Here ---
'94 JDM Ford Mustang GT Coupe
Monsterbishi
Postby evil_si » Fri Dec 31, 2004 9:23 pm
yup thats what its doing, high idle / surging, havent got the coolant lines connected,
but it also sounds like there is a huge vacuum leak, only getting 10" on the guage,
i cant physically see any were on the inlet were it could be sucking air in,
* is there a position for the intake air temp sensor on a late model redtop inlet?
test drove it tonite, first time as turbo, 8O oooohhh baby, cant wait to sort a couple of niggly things and shes all on.
evil_si
vacuum
Postby JasonZE » Fri Dec 31, 2004 11:13 pm
The wax stat is basically a big air leak! It just vents air from one side of the throttle body to the other you need to get water flowing through it if block the hole in front of the butterfly but if you do it will over fuel when cold and most likely not idle so i would suggest hooking water up to it.
JasonZE
Real Life Mechanic
Postby evil_si » Sat Jan 01, 2005 11:55 am
have now got water going thru it, still no difference to idle,
evil_si
Postby dohca » Sat Jan 01, 2005 11:58 am
i removed myne
and kneedit'ed them up
works perfect idle at 800~ rpm
my link doesent seem to care less car has never stalled when cold etc
the only thing i did was unscrew the air bypass valve a few turns to the idle was slightly higher
hope that helps
p.s myne was stuffed anyway this is why i did this
dohca
Postby evil_si » Sat Jan 01, 2005 4:19 pm
found it,
ok so i used the original 4agze throttle body on the redtop inlet,
turns out it doesnt seal properly around the out side :roll:
gotta find a normal t/b now.
evil_si
