Injectors
Injectors
Postby CAMB01 » Thu Jan 06, 2005 11:53 pm
What higher flowing injectors can be fitted to a Big port 4AGE that have the same ohm rating.
What would happen if the ohm rating wasn't the same?
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby Malcolm » Fri Jan 07, 2005 8:47 am
but if you do run resistors make sure you get ones that dissipate enough power, not just those little .5Watt ones from electronic stores.
Postby swamp » Tue Jan 11, 2005 7:18 pm
i unintentionally run high impedence injectors on my 4age and it gave it an odd power curve. had a flat spot between 4 & 5k but still run ok.
swamp
Users browsing this forum: Google [Bot] and 23 guests
