top speed of n/a sw20?
Postby deaf_rattle » Wed Jan 12, 2005 10:30 am
from oldschool.co.nz
R3DSKN wrote:me old sw20 mr2, nz new, standard with 14" factory alloys, 5spd, non turbo, non powersteer, targa top...... 260kph speedo, clocked 255kph on bp ultimate...@ Hutt motorway SH2.... Note: steering seems to vacate at 220kph
current ride: '77 esky, 4spd 1300.. Top speed: 115kph
Loaned it to a mate of mine to drop his misses off, he got booked (to my suprise) at 128kph.... hmmm maybe im just a phat kunt
255kph possible in an n/a sw20?
seems abit off to me
Postby CozmoNz » Wed Jan 12, 2005 12:14 pm
well, they have the gearing for it. just like ae111's. which is a bad idea in an engine with not that much torque (3sge vs 3sgte... no toruqe :P).
top speed of an ae111 is like 240kph? the gearing can take it there, the engine cant :). so i guess its probable.... i dont belive its standard... hey AL, could your sw20 do 255ish?
Rayne For President!
CozmoNz
Postby Al » Wed Jan 12, 2005 12:28 pm
Im not familar with the s54 box from the n/a, have a search on google for the ratios compared to the e153 box (turbo) ratios. Im pretty confident even a stock turbo sw20 could almost touch 250 without a limiter....provided you could keep it on the straight and narrow :)
Al
Postby Leon » Wed Jan 12, 2005 12:31 pm
I would eat my hat if an SW20 in standard form would pull 250kmh, the drag would be far too high.
If a standard SW20 did in fact pull 250kmh, once I finished eating my hat, I would buy an SW20 :)
Just because it's geared that high, doesn't mean that it can pull that theoretical top speed unless it was in a vacuum.
Postby blitza » Wed Jan 12, 2005 1:08 pm
maybee they have no rear wing..... got no p/s... maybee they were in somebody's draft.
MAD Industries Limited
blitza
Postby anthonym » Wed Jan 12, 2005 1:10 pm
Leon wrote:I would eat my hat if an SW20 in standard form would pull 250kmh, the drag would be far too high.
I hope you mean a stock NA SW20, or that your hat is made of cake or something :). I'm pretty sure a gen 3 turbo would be able to do it. FWIW I've seen 240kph in a near stock gen 1 turbo (on the track of course).
To answer the original question, no a stock NA could not do 250kph although I'm sure an indicated 255kph is entirely possible.
anthonym
Postby Adamal » Wed Jan 12, 2005 1:20 pm
Mine is pretty much the same as the first mentioned one (except I have aftermarket 15" wheels).
I've reached 220kph so far..... I took my foot off after that....
*I do not condone such actions*
Postby Adamal » Wed Jan 12, 2005 1:26 pm
And who the hell would you be drafting at 250kph?!?! 8O
Postby CozmoNz » Wed Jan 12, 2005 1:55 pm
Adamal wrote:And who the hell would you be drafting at 250kph?!?! 8O
well probbaly no one, a supra would get to 250 far quicker than you would and couldnt stay in his stream :), even a Mr2 turbo would blitz ahead >.>
so um... nothing? unless they wanted to do you a favour :P
and adamal, how long did it take you to get to 220?
CozmoNz
Postby Adamal » Wed Jan 12, 2005 2:00 pm
Can't remember, I was concentrating a tad too much on the road :P
Postby Muzzie » Wed Jan 12, 2005 2:12 pm
As you do when you're doing somewhat ludacris speeds.
Like the time I had the Diamante up to 240 (well somewhere around that, maybe quicker - 180 off the clock and I had the needle back up against the zero post.
And when i got my dads van to 161 - Genuine! (Tracked Via Sat Nav GPS :))
I also do not condone these actions, that was in my younger days - before I turned 18........
Muzzie
Regular Poster
Postby Adamal » Wed Jan 12, 2005 2:26 pm
18? What you mean "WAS in my younger days"? ;)
Postby Mr Revhead » Wed Jan 12, 2005 2:37 pm
me in my 20v :wink:
250plus in an mr2 has to be scary!! al reckons his is bad at 170 on the strip!! but then again his has soggy suspension with a heap of psi in the front tyres...
but id agree with nemisis, knowing how easily they hit 200 id say 250 is possible.... but i wouldnt want to try it
oh and another thing...
speed in accuracy.... its not unusual for speedos to be upto 10% out... thats 20kmh at 200kmh.....
Postby Adamal » Wed Jan 12, 2005 3:06 pm
Tell you what, we'll call a cop next time so he can clock me accuratly ;)
Postby pc » Wed Jan 12, 2005 3:14 pm
GPS is probably the easiest way of getting an accurate speed when you go past the end of your speedo. You will probably find there is at least 5% error if you calclate it based on revs.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby Leon » Wed Jan 12, 2005 3:16 pm
Yeah, I wouldn't believe any claims made from looking at a factory speedo, or from the "guessing how many cm past the 180 mark" the needle was at. Definitely at high speed, you're going to want to have a radar check or GPS check, rather than trusting a speedo.
I have a really useful photo I took of an XJS speedo sitting at an indicated 180mph (not kmh). Doesn't make it true :)
I think you'll find an SW20 turbo, even a gen 3 won't pull 250kmh.
Postby DJ » Wed Jan 12, 2005 3:25 pm
Top speed of a N/A MR2 is 137mph (Which works out to be 210kph)
Id have to be modified a bit or going down a bloody steep hill to get 250 haha :P
DJ
Postby FST4RD » Wed Jan 12, 2005 3:27 pm
I had my mr2, pod filter running 12psi, go off the 180km speedo in 4th and then hit the rev limiter in 5th gear. I'm not sure how fast that is, anyone got any ideas??? (all in controlled conditions)
1983 Mitsubishi Starion
1995 Subaru legacy GT SW
FST4RD
Postby kingcorolla » Wed Jan 12, 2005 3:32 pm
i think deaf is just thinking about faming this guy for claiming 250 :roll:
1983 Carina AA63 4age
kingcorolla
