Machining brake rotors
Postby lil » Wed Jan 19, 2005 7:20 pm
I am going to put some ebc green stuff brake pads on the front of my aw11 next week, should I get the rotors machined?
I have it done before on previous cars of mine when changing brake pads but that has usually been because there were small grooves worn into the rotor just through general wear, and also, on another occasion because the brake pedal was juddery(is that even a word?) meaning that the rotors were probably slightly warped. The rotors on the mr2 however look and feel fine to me.
So, should I get them machined anyway or will they be sweet?
I have heard that after having rotors machined, you shouldn't then put your new high performance pads straight in, you should bed them in a bit with the old pads and then put the new pads in, is this true?
Anyone know where is the best/cheapest place to get rotors machined in Hamilton? I think last time it cost me about $50 for two rotors at Apex (seems expensive).
lil
Postby Twolitre » Wed Jan 19, 2005 9:04 pm
Yes machine your disks, $50 sounds about right
Twolitre
Postby thaphatty » Wed Jan 19, 2005 10:07 pm
if you talk to karl in the blue building on the corner of kent and empire street he knows a good guy,
the dudes 1 wack c**t but he does a good job, hes mobile too.
i think its along the lines of "waikato mobile brake something something"
thaphatty
Postby Stu- » Wed Jan 19, 2005 10:45 pm
Just a quick question : can you have factory rotors slotted if they're new enough instead of buying aftermarket slotted rotors?
Ta
Project Thread
Stu-
Postby lil » Thu Jan 20, 2005 9:54 am
Twolitre wrote:Yes machine your disks, $50 sounds about right
I will then....dont want to skimp in the name of safety.
lil
Postby Lanius » Thu Jan 20, 2005 11:22 am
www.dba.com.au
Look up the part number for your car under Toyota, then take the part number to Super Cheap Auto and request that part. Have discovered that a friend who did this got a pair of Brembo slotted front disks for his Cortina for NZ$90!
I'm heading to SCA on my lunch break today to ask how much a set of new disks for my 185 will cost :)
Lanius
Postby TygerTung » Thu Jan 20, 2005 11:41 am
If your discs are in good condition, ie not grooved, you shouldn't machine them, as there is a minimum thickness for your discs, and you shouldn't go under this, if you do it is extremly dangerous. Machining your brakes too often will bring your discs to the minimum thickness fast.
TygerTung
Re: Machining brake rotors
Postby GT4 20 » Thu Jan 20, 2005 11:54 am
lil wrote:I am going to put some ebc green stuff brake pads on the front of my aw11 next week
All IMHO of course, but EBC Green Stuff are absolutely cr@p. Wouldn't even put them on my push bike. They may produce less dust than other pads, but they certainly can never be classed as a decent pad - even less so if you are after something that is a good 'performer'.
Gary
1999 Subaru Legacy B4 RSK TT
GT4 20
Postby Twolitre » Thu Jan 20, 2005 12:44 pm
TygerTung wrote:If your discs are in good condition, ie not grooved, you shouldn't machine them, as there is a minimum thickness for your discs, and you shouldn't go under this, if you do it is extremly dangerous. Machining your brakes too often will bring your discs to the minimum thickness fast.
That's why you buy new disks when they go under the minimum thickness, but his car is a light car with not much weight in the front so it shouldn't chew through the disks too much so they're probably fine but the place machining them will tell him if they need replacing or not.
Twolitre
Postby TygerTung » Thu Jan 20, 2005 12:58 pm
Well why machine them if they arn't grooved?
TygerTung
Postby KinLoud » Fri Jan 21, 2005 3:15 pm
GT4 20 - I'm very curious... what part of the performance of EBC Greenstuff don't you like?
My experience:
Cold - poor braking action, lots of pedal effort needed.
Warm/Hot - very good, good feel, no fade.
Not really suitable for a daily driver, but great for the track.
Ken
Hamilton
021 408 863
Postby lil » Fri Jan 21, 2005 3:46 pm
GT4 20 wrote:All IMHO of course, but EBC Green Stuff are absolutely cr@p. Wouldn't even put them on my push bike. They may produce less dust than other pads, but they certainly can never be classed as a decent pad - even less so if you are after something that is a good 'performer'.
Gary
I was reccomended green stuff by an experienced member of the mr2 club who has much trackday experience.
I am not disputing your experiences 'GT4 20' with greenstuff, but could you please be a bit more specific with what you dont like about them, conditions, usage etc?
Also 'GT4 20', could you please provide me with details of what you consider a better performing pad with a similar price tag?
lil
Postby Lanius » Fri Jan 21, 2005 4:47 pm
Lanius wrote:www.dba.com.au
As mentioned before ... went to SCA and asked about the part number in regards to my car (ST185 Celica), and a PAIR of performance slotted front rotors will set me back $143!
*starts saving*
I'll let you know when they arrive, and whether or not they're worth the investment :)
Lanius
Postby Twolitre » Sun Jan 23, 2005 1:39 pm
Hey Lanius that's cheap for brand new slotted rotors!! Do they have to come ex-Aus and how long will you have to wait?
I hope you realise that there's 2 different sizes of St185 rotors, one for widebody single calliper and one for jdm normal body twin calliper, and DBA being an Aus co. will prob only make the rotors for the widebody as that was the only model they got, should've measured yours first and compared the dimensions to that of the part catalogue.
Ps. What SCA branch did you go to?
Twolitre
Users browsing this forum: Google [Bot] and 53 guests
