Drilling holes in air box?
Postby MINTFX » Sat Jan 22, 2005 9:18 pm
Hey, A while back my friend showed me a site where a bunch of people tested a crap load of different intake systems on a mitsi FTO. They tested different panel filters, cold air boxes with pod filters, and they also tried just drilling holes in the factory airbox. Suprisingly drilling the holes in the airbox gave them the most power increase. Do you guys reckon its worth wrecking a good airbox by putting some holes in it to get some more airflow or just leave it? Any comments would be great.
MINTFX
Postby celica_tommo » Sat Jan 22, 2005 10:14 pm
no
celica_tommo
Postby Ae92typeX » Sat Jan 22, 2005 10:14 pm
really depends where the air box is imo, if its right in the engine bay- as many are, you will just be sucking more hot air...flow may be better, but hot air less dense.
If you were gona do it, why not just get another ond from the wreckers or something, go for it, and then keep your good one if it dosent work out.
Ae92typeX
Postby MINTFX » Sat Jan 22, 2005 10:33 pm
Mmmm, I guess it would be a waste of time as the holes would just suck in warm air, defeating the purpose. Looks like I will have to move the battery to the boot and but a chrome pipe n filter and make a box. Damn battery is a pain in the arse in AE82s
MINTFX
Postby CozmoNz » Sun Jan 23, 2005 1:14 am
Rayne For President!
CozmoNz
Postby MINTFX » Sun Jan 23, 2005 8:25 am
Ahhh thanks for that, Id like to finish reading it but theres no way im paying.
MINTFX
Postby strap-on » Sun Jan 23, 2005 10:13 am
has anyone paid for it ? then they could just post it up
strap-on
Postby wde_bdy » Sun Jan 23, 2005 10:19 am
Just duct a decent cold air feed into your factory airbox.
Callum
wde_bdy
Postby ChaosAD » Sun Jan 23, 2005 1:11 pm
Just do what im doing. Make a cold airbox where the factory airbox used to be. You can do anything with fibreglass. well, almost anything.
ChaosAD
Postby atmosports » Sun Jan 23, 2005 2:37 pm
Here's all the text from that article
These days, most people know that placing an exposed airfilter under the bonnet is just asking for the engine to take big breaths of hot air. To avoid that outcome, it's now common to fit a cold air intake - often abbreviated to 'CAI' - and seal it to the airbox.
However, what's generally not realised is that if a positive pressure can be generated in the cold air intake, the engine will perform better again. Actual on-road measurements that we have made ("Eliminating Negative Boost - Part 5") have shown that at speed, a good cold air intake can easily have sufficient air pressure within it to completely cancel the flow restriction of the aircleaner. So, even though the effect of ram air on performance isn't huge, there's a worthwhile gain that can be made.
But getting that pressure build-up in the duct requires that the mouth of the cold air intake be sited in an area of high pressure.
And where's that, then?
Pressures
As the car moves forward, air is deflected above, below and to each side of the car. As an example, take the flows occurring along the centreline of a sedan that has a very good drag coefficient (ie it's slippery) like the pictured early Lexus LS400. Some of the air is deflected over the top of the bonnet, passing along the bonnet, flowing up the windscreen, along the roof, down the rear window and then leaving the car's body at the trailing edge of the boot. (To keep the flow attached to the body in the described manner, the car must have gentle changes of angle only - especially from the roof to the rear glass to the bootlid.)
Other air is deflected beneath the car, flowing along an engine under-tray and then getting mixed with the turbulent flows exiting the engine bay (the air going thorough the radiator has to get out somewhere!) and the other turbulence created by the exhaust and suspension, not to mention the spinning wheels.
But back to the front of the car...
At the front there must be a point above which the air goes over the car, and below which the air goes under the car. This is called the stagnation point, and it is here that there will be the greatest pressure developed on the front of the car as it moves forward. This graphic of a Mercedes shows the high-pressure stagnation area in red, lesser high-pressure areas in green, and the low-pressure areas in blue. (They're low pressure areas cos the airflow is being accelerated around a curved surface at each of those spots.)
And hey, that's all very well and good - but how do you find where the stagnation point is on your own car? And what if it's impossible to site the intake for a cold air duct there anyway? How do you rank the quality of other potential sites?
Test Set-Up
Finding the pattern of the positive pressures acting on a car is easy and can be carried out very cheaply. The testing can be done in a number of ways, including using a manometer, Dwyer Magnehelic gauge, or as we've done in this particular story - using a very sensitive pressure switch.
The last approach has some advantages - it's very cheap, very easy, and there's no likelihood of manometer fluid going all over the carpet!
The switch that is used is the Micro Pneumatic Logic Pressure switch available in the AutoSpeed Shop for $11.95. An extraordinarily sensitive switch, it is factory set to trigger at about 1 kPa (0.145 psi) and is perfect for this application.
The test procedure is simple:
Buy some small diameter plastic hose that fits tightly over the pressure switch nipple. I bought 5 metres of clear plastic hose from the local hardware store for 70 cents a metre.
Place the open end of the hose at the location that you are investigating, then run the tube back in the cabin, holding it in place with pieces of good quality masking tape. (Good quality so you don't harm your car's paint!)
Push the other end of the hose over the pressure switch.
Connect the pressure switch to a buzzer, power and earth so that it sounds when the switch is subjected to pressure. The pictured AutoSpeed Variable Volume Buzzer costs $4.95 and is fine for the application. Alternatively, if you have a multimeter with an audible continuity function, you can connect this to the pressure switch, so that the meter beeps whenever the switch is subjected to pressure.
Incidentally, if you're wondering how to go about connecting the wires to the pressure switch (it uses odd, small spade terminals) all that you need to do is pull off the back mounting section, revealing the terminals which can then be easily soldered to.
When you have that all set up, go for a drive, with someone else in the car to write down the results.
Testing
Because the pressure at which the switch clicks over is preset, you can't directly measure the different pressures acting on the front of the car. But you can still work out really well what's going on.... How?
What you need to do is monitor the speed that you're travelling at when the buzzer sounds.
So let's take the example of the car used here. The '91 Lexus LS400 has a section of bumper beneath the large headlights where there is the appearance of bars forming a grille, but in fact the bumper is solid. It was my guess that this would prove to be a high-pressure area, and so it proved. What happened was that with the open end of the hose positioned in this spot, the buzzer sounded at about 85 km/h. (Note that you want to do the testing on a fairly windless day, and be wary about following cars too closely as this noticeably upsets the results!)
So at around 85 km/h there was enough pressure being generated at this location by the force of the airflow to trigger the switch.
Next I moved the pressure tap to just behind the radiator grille, between the headlights. At 85 km/h the buzzer didn't sound, nor did it at 90 or even 100 km/h. In fact the car had to be moving at 110 km/h before the buzzer came alive. That same result was also gained with the probe placed against the front of a headlight.
So, since the Lexus had to be moving much faster to generate the same pressure, in general the pressure across the upper grille and headlights was lower than at the first probe position.
The testing therefore showed that an air intake positioned beneath the main part of the bumper would work well - although of course with the intake in this location, the possible ingestion of water lying on the road should also be considered. (Air-borne water normally causes no dramas.)
But what about at the base of the windscreen? Since time immemorial the intake to the cabin ventilation system has been sited here, because this is generally a high-pressure area. It's also common to place the mouth of cold air intakes through into this plenum volume - in fact we've covered one such approach at "Free-Flowing a Miata MX5"
But how did this location actually compare for pressure with the best spot already found? In the Lexus it is way poorer: with the probe placed a little off-centre at the base of the windscreen, the car needed to be travelling at 150 km/h before the switch triggered. However, the pressure was a little higher at the mid-point of the windscreen - 145 km/h triggered the switch.
So the pressure measured at the base of the windscreen was actually the lowest yet recorded.
Probe Location Speed Needed to Trigger Switch
(higher = lower pressure being found)
Blocked grille in lower front bumper 85 km/h
Radiator grille between headlights 110 km/h
Surface of headlight 110 km/h
Base of windscreen, centre 145 km/h
Base of windscreen, off centre 150 km/h
And what about the standard Lexus cold air intake? The LS400 uses an over-radiator intake, common in many cars. Forward-facing, it is a preferred factory location because it places the intake well above water on the road, conceals its mouth from the direct pick-up of dust, and has the potential to gain some positive pressure. But was the LS400's standard intake in fact developing any positive pressure?
With the probe placed in the intake, some further testing was undertaken. At 160 km/h, full throttle, there wasn't sufficient pressure build-up to trigger the switch, but immediately the throttle was lifted at these speeds the buzzer sounded. What was happening was that the massive amount of air being demanded by the 4-litre V8 meant that air passing into the duct was being drawn straight into the engine - and not building up a pressure. However, with the throttle closed, the pressure build-up was obvious. In fact, with the engine drawing only idle air consumption, the buzzer sounded all the way down to 110 km/h.
This showed that the duct, which draws air from just behind the radiator grille, was being subjected to the same positive pressure recorded earlier at that location.
So yes, the standard duct is in a pretty good position - not the best possible for ram air pressure, but taking into account those aforementioned compromises about dust and water, yep, pretty good.
Conclusion
Spending under twenty bucks and an hour of your time can give you a clear picture of some of the aerodynamic pressures acting on the front of the car. That'll mean that you can locate the engine intake to make the most of the free power often going to waste. You'll certainly avoid making some of the glaring errors that we occasionally see... like drawing air straight from the wheel arch - a low-pressure area in many cars!
But keep in mind that once you've found the best position for the mouth of the intake, seal it all the way back to the filter. You don't want that precious pressure just dissipating itself in the engine bay....
atmosports
Postby CozmoNz » Sun Jan 23, 2005 3:09 pm
bet me to it :)
theres also a part 2 if your interested
CozmoNz
Postby strap-on » Sun Jan 23, 2005 4:03 pm
im interested
strap-on
Postby CozmoNz » Sun Jan 23, 2005 4:06 pm
You have pm
CozmoNz
Postby Stealer Of Souls » Sun Jan 23, 2005 8:26 pm
http://www.geocities.com/srsvengence/1023.pdf
Just for those cheapies!
http://www.geocities.com/srsvengence/1361.pdf
http://www.geocities.com/srsvengence/1370.pdf
http://www.geocities.com/srsvengence/1379.pdf
And a few more for ya to browse over. I don't know if those links will work. If they don't drop me a line and I'll email them to ya. I'll look into making my logon/id more generic so that everyone can just log on themselves....
Oh yeah... And everyone be cool... I'm technically risking my access by doing this... Ain't I nice!
'86 AE85.5 Levin
Stealer Of Souls
Postby Stealer Of Souls » Sun Jan 23, 2005 8:28 pm
Hot4s has a good idea too...
Rather than just drilling random holes. But the side off the airbox that is facing the headlight (if yours does). I've just done this. Still yet to report any real improvements. But only really expecting some at high speeds/rpm....
Don't think my car has any real breathing problems at low speed/rpm since its just a stocker...
'86 AE85.5 Levin
Stealer Of Souls
Postby MINTFX » Mon Jan 24, 2005 11:14 am
I think ill skip on drilling some holes, Im probly going to end up getting one of those chrome pipes with a filter and end up moving my battery to the boot and making a cold air box out of some heat shield stuff you can get from repco and mould into whatever you want. Thanks for that article that was a good read.
MINTFX
Postby DeeCee » Mon Jan 24, 2005 11:28 am
stealer - can you email to me please - deecee23@gmail.com
thanks
GT Four Adovansu
DeeCee
Users browsing this forum: Google [Bot] and 41 guests
