Exact PCD and Offset for Caldina GTT wheels?
Postby snwtoy » Tue Jan 25, 2005 10:44 pm
As above, does anyone know?
snwtoy
Postby snwtoy » Wed Jan 26, 2005 6:25 pm
Fivebob where you at? :)
snwtoy
Postby fuel » Wed Jan 26, 2005 9:11 pm
PCD will be 5x100mm and offset will be between 40 and 50mm.
fuel
Postby fivebob » Thu Jan 27, 2005 12:29 am
snwtoy wrote:Fivebob where you at? :)
Busy pulling the left rear axle out of my GT-T, damn the bastard who decided that a drum park brake was a good idea, took me an hour to figure out how to pull it apart, :evil: putting it back together will be a bit of a challenge too.
As I posted on the list PCD is 5 x 100 offset for a 7" rim is +35
http://www.takakaira.com/rimsandtyres/r ... arims.html has most of the Toyota models listed with PCD, recommended offset and tyre sizes for aftermarket rims.
Postby rodstr » Sun Jan 30, 2005 8:22 pm
i was told 5x100 +40 from toptown tyres, on my factory rims it says 39
rodstr
Postby H1S_SUB » Mon Jan 31, 2005 12:06 pm
its the same as a subaru 5x100 +48mm offset, the offset is very inportant for front caliper clearance when going to a bigger mag, ive just got enough room to put a piece of paper between the wheel and rim but its prolly dependant on the rim you want to put on aswell
H1S_SUB
