smokabitabud wrote:ok so ur saying aluminium is just as good as chrome??????
Everything you do to your car depends on what you're after ... "show" or "go". If you want the car to be "bling" then go for chrome and lights and everything you need to get the attention you're after. You have to be prepared to pay for it though.
If you're after a car that performs well and just looks decent without being over the top, then save your money, and get whatever you need to do the job instead of the "bling" stuff. An aluminium piece of pipe will do exactly the same job as a chrome piece. At the end of the day, the only people who look under the bonnet are you and your mechanic.
Just be aware that you're never going to get the kind of performance out of a 1600 NA as you will out of a 2 litre turbo, so if you're after some real power, rather leave your car stock and save for something that came out from factory with more power. Those cars tend to have stronger parts (suspension, brakes, engines etc) than their more economical brethren, and are far easier to tweak for better results.
Having said all of that, BZ-G does have a pretty good site linked above, and he's on the right track with regards to modifying a car (brakes and suspension etc as well as more power), so it would be a good place to get some ideas.
