ChaosAD wrote:There is nothing wrong with the standard genuine headgasket, the different sizes are to fine tune the compression ratio and also give a bit more quench/squish.
TRD prices are a lot better than they used to be, my .8mm TRD headgasket set me back $99 but that was a pretty good deal.
TRD Man wrote:Actually, the std gasket used to be 1.0mm. I'd be surprised if this has changed.
We almost always recommend & sell the 0.8mm TRD gasket which we always keep in stock here in Wellington. Using the 0.5mm gasket can require the valve pockets to be machined to avoid contact.
As Warwick has stated, the application of a TRD gasket raises the compression ratio by so little fuel octane is not an issue.
Users browsing this forum: No registered users and 35 guests
