1UZ into an *A70 chassis...?
Postby Silent Knight » Wed Feb 02, 2005 5:57 pm
Hey all,
I am planning as a next project to pop a 1UZ into an *A70 chassis. What I am trying to find out is if anyone here has had much experience with 1UZs or have tried doing the conversion before........
I need to know how much if any sort of modification will have to be done to the engine bay to make it fit?
Now from what I know the motor is not very big and is mostly just a square about 800x800x800 plus or minus. What I plan on doing is to remove EFI and just put a big carby on it to minimise wiring and things to go wrong.
I haven't done this before so if anyone has any suggestions as to the easiest way to just convert it to a carby that would appreciated
Also the mounts in the engine bay......now from what I know in the z30 soarers the mounts in the bay are the same for the 1JZ and the 1UZ. Would this be the same aswell for an *A70 or would I be asking for to much?
Changing the mounts in the engine won't be a problem really but I just need to know if there is an off chance of it fitting in.....
Last thing is the sump on the 1UZ....it has 3 kinds of sumps rear, mid, front. Wich one would I need to use to fit the motor into a MK3?
Hanré
Silent Knight
Postby wde_bdy » Wed Feb 02, 2005 6:15 pm
http://forums.toymods.org.au/
Probably your best place to start, but search thoroughly before you ask. For carby setup look towards the stockcar guys.
Callum
wde_bdy
Postby deaf_rattle » Wed Feb 02, 2005 8:24 pm
Postby scotts2hot » Wed Feb 02, 2005 11:02 pm
It's different, and it's cool but is it really worth the effort unless your planning to turbo it as well?
scotts2hot
Postby Silent Knight » Wed Feb 02, 2005 11:27 pm
Haven't decided wether I will turbo it or put a blower on it......either way I am going to do the conversion sooner or later :wink: :wink:
I am probably more keen on the idea of a blower though but will have to wait and see...
Silent Knight
Postby 92GTApex » Thu Feb 03, 2005 2:54 pm
www.lextreme.com
www.quest4.co.nz
quest 4 have one on there site that they did
SAnd theres a whole section dedicated to 1uz in supras on lextreme, probably your best bet for information
Logan
Current ride: 92 Levin GT Apex
Current project: 91 Levin GT Apex (Crashed - It wasnt me)
www.area-51.co.nz
www.toyperformance.org.nz
www.lextreme.com
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1731
92GTApex
Postby 92GTApex » Thu Feb 03, 2005 3:03 pm
www.lextreme.com
www.quest4.co.nz
Logan
www.area-51.co.nz
www.lextreme.com
92GTApex
Re: 1UZ into an *A70 chassis...?
Postby RunningRich » Thu Feb 03, 2005 3:11 pm
Silent Knight wrote:What I plan on doing is to remove EFI and just put a big carby on it to minimise wiring and things to go wrong.
Philistein! :-P
Richard
http://gtfour.supras.org.nz
RunningRich
Users browsing this forum: Bing [Bot] and 16 guests
