Adamal wrote:Then her hands started going to my funny places........
sometimes it wont go above 6 psi but then all of a sudden it will go back to normal and top out at about 9 psi
RBRCHKN wrote:chinken man ya dirty poon tank
my sw has a bit of a problem that sounds similar. sometimes it wont go above 6 psi but then all of a sudden it will go back to normal and top out at about 9 psi
mr2_t wrote:Heres a link to my dyno chart - stock SW20 turbo, with a gutted cat. 10 PSI is where it tops out generally.
http://rjm.no-ip.info/stuff/dyno.jpg
Chickenman wrote:I actually got the good ol' limp mode the other day... Gas up here is pretty sh*t, I do find Gull a little better though.
New turbo... or get this one reconditioned? What you guys think?
It's not that I really want more boost, I just want a more sustained boost. (Right through to 6-7000rpm) where as it's dropping off to 6lbs at higher revs.. totally useless in first really.
Much of a mission to gut the cat?
