supercharger pulleys???
Postby moses » Thu Feb 03, 2005 11:34 am
does any1 no where i could get a bigger s/c pulley???
moses
Postby lorolla24 » Thu Feb 03, 2005 11:46 am
yep, you can either buy one from WAR Motorsport for a large amount of money OR you can do what i did and make one (175mm dia) but you need a lathe and some engineering expreance OR find one some one is selling on this site. got 14 psi with that size and frontmount.
lorolla24
Postby Crimson Tears » Thu Feb 03, 2005 12:20 pm
If you want more boost out of your supercharger, why would you want a larger pulley? You'd want a smaller pulley, so that the supercharger will spin faster and make more boost.
Crimson Tears
Postby Pelo » Thu Feb 03, 2005 1:23 pm
Its simpler to make a larger crankshaft pulley than to make a smaller supercharger pulley due to the sc clutch setup etc.
Pelo
Postby Charged1 » Thu Feb 03, 2005 6:32 pm
Hi PM evil_si , Simon put one one my car 175mm , you just exchange your stantard crank pulley plus 450 and away you go , and that includes fitting , huge increase in power for cheap bucks , give those vtec boys a scare as your GTZ will pull hard , cheers
Charged1
Postby evil_si » Thu Feb 03, 2005 6:36 pm
war motor sport discontinued the pulleys about 2 years ago from what i understand
the crank upgrade is a lot easier than the s/c pulley, as it basically will just bolt on in place,
i can supply a harmonic type 175mm pulley ( exchange ), new tensioner and new belt, for $400
evil_si
Users browsing this forum: Google [Bot] and 23 guests
