External Injection Fuel Pumps
Postby 85AW20v » Sun Feb 06, 2005 10:54 pm
Any ideas which cars run these as I need to fit a surge pot to the AW and need the extra pump for fuel delivery to the injectors. The in-tank pump will be filling the surge pot. Doesn't have to be Toyota.
See ya
Simon
85 MR2 20v
85AW20v
Postby Monsterbishi » Mon Feb 07, 2005 8:22 am
Just buy one brand new, www.nzperformance.co.nz has a huge range of them, Bosch, Walbro, etc...
--- Cut Here ---
'94 JDM Ford Mustang GT Coupe
Monsterbishi
Postby ee904age » Mon Feb 07, 2005 12:10 pm
Vl commodore pum has proven more than capable for me.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby Twolitre » Mon Feb 07, 2005 1:07 pm
Yeah VL's are the most popular, MA61's also run external fuel pumps, but as has been said aftermarket external fuel pumps aren't that expensive.
Twolitre
Postby rxtoy » Mon Feb 07, 2005 2:59 pm
i'm running a 255 litre per hour internal pump for my external, i just used a large outlet with a bit of air compressor hose between the surge tank and the fuel pump inlet. works fine and saved me a fair bit of $.
Matt
current rides:
76 stout
77 B1600 13B J port
rxtoy
Postby YeMs » Mon Feb 07, 2005 8:47 pm
yeh as mentioned VL commodore pump. exactly the same as used on the rb20de/t skylines. usually not much more then $80 from a wrecker.
Your local Hybrid Elite tech
YeMs
Postby craigt » Mon Feb 07, 2005 9:06 pm
Bosch make some excellent external pumps, just watch the pressure of your replacement pump, may need a good pressure regulator
If it doesn't fit, force it.
If it breaks it needed replacing anyway!
AE101 4AGZE
KP60 4AGTE project
craigt
