W55 into KP60
W55 into KP60
Postby craigt » Tue Feb 08, 2005 6:53 pm
Im going to be fitting a W55 into my Starlet behind a 4AGTE, hopefully using a Niteparts bellhousing. Which is the best shifter location to use,
as these gearboxes can have 4 different shifter locations?
Im not terribly worried if I have to relocate the shifter hole slightly further rearward. Any other problems fitting these boxes into the tunnel?
I havent mounted the engine yet, and I realise I'll have to make a rear gearbox mount.
If it doesn't fit, force it.
If it breaks it needed replacing anyway!
AE101 4AGZE
KP60 4AGTE project
craigt
Postby evil_si » Tue Feb 08, 2005 7:05 pm
we just bolted on of brendons bellhousings up to our 4agte with w55 in a ke30, it came with the center-ish shifter and was sweet as
as for mounts etc they were way out so just made up a cross member to suit
evil_si
Postby wde_bdy » Tue Feb 08, 2005 8:58 pm
Tunnel is tight, needs quite a bit of persuasion. I cheated and used a different tunnel and shifted the firewall back.
Callum
wde_bdy
Postby terrytuffguy » Tue Feb 08, 2005 11:34 pm
4agte into starlet? Where do people get these crazy ideas! haha
You have widen the shit out of the tunnel, bileve me :P
My 4AG powered starlet puts out 227rwkw & 12.39 @ 115mph........ YEA RIGHT, Tui.
terrytuffguy
Postby terrytuffguy » Tue Feb 08, 2005 11:37 pm
P.S. You might be interested in my diff when I have finshed with it :)
terrytuffguy
bah
Postby ezy10s » Wed Feb 09, 2005 5:18 pm
no need for extreme mods as metioned above- just raise the gbox into posn, wehre it hits the tunnel just massage(see BASH) it a little, it really doesnt take much
Oh and I found on my one the centre shifter posn worked a treat.
Member #244
ezy10s
Postby terrytuffguy » Wed Feb 09, 2005 7:17 pm
Well I had to widen my tunnel quite a bit! To give the gearbox clearence and also makes taking the box out easier. Bashing the tunnel is a bit gash tho, but it's up to you. But I do have my box sitting right up into the tunnel.
terrytuffguy
