Speedo Question, GTZ box into AE101 FX
Postby Rob_GTZ » Wed Feb 09, 2005 10:25 pm
Anyone fitted a GTZ box into a AE101 FX-GT?? What did you do for the Speedo? as the GTZ Box we have is a Cable drive type speedo, & the FX one was a Electronic Sensor Type.
Any ideas appreciated
Rob_GTZ
Postby THA SHZ » Thu Feb 10, 2005 12:20 am
take ur electronic one out and put it in the gtz itl fit i ust changed mine but the reverse of urs i needed the cable not electronic :D
THA SHZ
Postby Rob_GTZ » Wed Feb 16, 2005 10:58 pm
I had thought of that, but from comparing the two side by side I don't see anyway that they'll swap over.
Anyone Else?
Rob_GTZ
Postby UTERUS » Thu Feb 17, 2005 5:58 pm
The cable drive and electronic drive units on the gearbox unbolt, swap 'em over.
It is a myth that emos are contagious, and you may be infected. However, it is still widely accepted to wash your hands after physical contact
UTERUS
Postby matt dunn » Thu Feb 17, 2005 9:51 pm
Rob_GTZ wrote:I had thought of that, but from comparing the two side by side I don't see anyway that they'll swap over.
Anyone Else?
They wont look like they swap pver but they do.
From memory a 10mm spanner to undo the clamp & then twist it bacl and forth to free it up and pull it out.
Matt
Postby phatman3801 » Sun Feb 20, 2005 6:43 pm
jst a question...would a gtz ae101 gearbox go ne good in a ae111 blacktop??
phatman3801
Postby matt dunn » Sun Feb 20, 2005 7:17 pm
phatman3801 wrote:jst a question...would a gtz ae101 gearbox go ne good in a ae111 blacktop??
I doubt it,
It will probably fit, but there are a bit too heavy, and the blacktop's main advantage is it's lack of internal weight.
Be kinda like fitting a much heavier flywheel,
