4-2-1 Extractors or 4-1? Pros and Cons?
Postby LEVIN GTV » Thu Feb 10, 2005 4:06 am
Hey guys,
Im looking at some extractors for my 4age. Ive passed the 20v extractors on my 16v and going to get some custom ones made up.
Basically im not to sure whether to go with 4-2-1 or 4-1?
What are the pros and cons of each???
Any help would be appreciated
LEVIN GTV
Postby Stealer Of Souls » Thu Feb 10, 2005 9:21 am
I'm not 100% sure on this but...
I heard 4-1 give slightly better top end performance, and 4-2-1 give better low end performance when compared to each other.
'86 AE85.5 Levin
Stealer Of Souls
Postby Mr Revhead » Thu Feb 10, 2005 9:26 am
yup 4-2-1 gives better midrange, so thats what you want on a road car.
the stock ones are really good, hard to improve on them.
so its a 16v? why not use the 20v ones??? the are excellent.
even the stock 16v ones are damn good. unless youv spent a lot on the engine you wont find any gains there....
Postby ChaosAD » Thu Feb 10, 2005 12:04 pm
So will the 20v ones give any gain over the standard 16v manifold? or is it just that they look a bit better and are lighter
ChaosAD
Postby Mr Revhead » Thu Feb 10, 2005 12:35 pm
i beleive they are better.
on a modded engine they will help. but i havnt seen any dyno figures...
i wouldnt expect a dramatic increase.
lets put it this way... if i had a 16v id fit 20v extractors
Postby Crampy » Thu Feb 10, 2005 12:59 pm
My mates just reccently changed from some 4-2-1 to a 4-1 set of extractors on his heavily modded Honda Civic. He made 28 HP at the wheels!!! :twisted: :twisted: That's some crazy $hit man...
Why can't we get insane gains like that??? :( :( :(
Crampy
Postby Mr Revhead » Thu Feb 10, 2005 1:04 pm
probably because they were crap to start with....
and theres more to it than peak hp...
Postby Crampy » Thu Feb 10, 2005 1:13 pm
Yeah that's what I thought, but they were a very good set of extractors to start with.
His car had done a 12.8 at Meremere. Now he's getting a Link installed and tuned and see what she's good for after that hike in power...
It's a crazy ass car!!!
Crampy
Postby Rollux » Thu Feb 10, 2005 1:35 pm
A Honda needs all the help it can get.
BTW, I got close to 25hp gain with a good set of headers on my 16v :wink:
2002 Allex RS180 6 Speed
Racing a Honda is like competing in the Special Olympics. Even if you win, you are still a Retard.
Nissan Motorsport = Nismo
Honda Motorsport = Homo??
Oversteer is when the Passenger is scared. Understeer is when the Driver is scared
Rollux
Postby Mr Revhead » Thu Feb 10, 2005 1:39 pm
how? and is it a 16v 4age or 16v 302 v8 :wink:
was it stock?
what was the rest of the power curve like?
torque?
Postby LEVIN GTV » Thu Feb 10, 2005 3:56 pm
Rollux wrote:A Honda needs all the help it can get.
Yes would be interested to know what headers you used on your car!
Basically im in two minds what i want, i mean i would love top end power, and the sound of 4-1, but my mind also tells me that i should go 4-2-1 as they are for more road use.
I CANT DECIDE!
LEVIN GTV
Postby Dr-X » Thu Feb 10, 2005 4:50 pm
$10 says that without the help of a dyno graph, you wouldnt tell the difference.
Dr-X
Postby vvega » Thu Feb 10, 2005 4:58 pm
Dr-X wrote:$10 says that without the help of a dyno graph, you wouldnt tell the difference.
20 dollars says that even if he had a dyno graph you still wouldnt have a clue :D
v
vvega
Postby Dr-X » Thu Feb 10, 2005 5:05 pm
OMG you're sooo funny!
Dr-X
Postby vvega » Thu Feb 10, 2005 5:39 pm
OMG your so stupid
nuff said bout that
vvega
Postby kingcorolla » Thu Feb 10, 2005 8:24 pm
yes im also down the extractor path.
Im pondering custom made, ive got the fabrication sorted at work. But want to research a little more about split pusling, and length tuning with a cammed engine.
Is mig welding suitable? Ive heard stainless steel expells less heat, but will have to be tig welded. That rules that s/s as i only have mig at work, so Im planning to use steam pipe.
Whats a good tube diameter? or will it vary slightly with such modifications as raised c/r, increased valve duration, flow rates etc? (na) Also collector diameters?
any other things to think about? thanx
1983 Carina AA63 4age
kingcorolla
Postby vvega » Thu Feb 10, 2005 8:35 pm
ok ill make this easy
extractor lenght is based off cam timming
stainless is fine
steam tube is good for turbos!!!
titanium is good to but is a cock to weld
mild steal bought in u bends is your easyiest option
4:1 is easier to build and tune
4:2:1 is harder to tune and get right
so get all ya cam details togethier
work out your port lenght
and go from there
v
vvega
Postby LEVIN GTV » Thu Feb 10, 2005 9:12 pm
yeh but what is best 4-2-1, or 4-1????
I can decide
LEVIN GTV
Postby Drifter4ag » Thu Feb 10, 2005 9:17 pm
yall just need to run stockers or buy some from japan where they are tried and tested.
GOGO
Garage |-" '|
Current Rides
Vitz RS :D
Previous,
JZX91 MARK II CHASER
Drifter4ag
Postby vvega » Thu Feb 10, 2005 9:35 pm
Drifter4ag wrote:yall just need to run stockers or buy some from japan where they are tried and tested.
GOGO
sounds like the plan
as for whats best
that is a question you have to deside there both best for different things
v
vvega
