Compression Pressure for 4agze (afm + map)
Postby ~SlideWays~ » Wed Feb 16, 2005 2:06 pm
I've searched and can't find.
I need to know what the compression pressure should be on both the MAP 8.9:1 and the AFM 8:1 gze's
My MAP small port was at least 180 on each cylinder does that sound right? I'm just about to test my AFM big port now but i assume it'll be less because of the compression?
Plus is there anyway to do the test wrong and get a bad reading?
Thanks in advance. 8)
~SlideWays~
Postby ~SlideWays~ » Wed Feb 16, 2005 3:35 pm
ok tested big port afm gze and they're all around 155psi compared to the Smallport's 180psi.
Would this be because of the compression ratio?
Are these decent readings for both engines?
~SlideWays~
Postby EVLGTZ » Wed Feb 16, 2005 3:48 pm
Sounds about right. As long as they consistent then that should be good enuff. Dif testers give different readings so yeah sounds fine
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby ATAl » Wed Feb 16, 2005 5:06 pm
I got 180psi on all cylinders on my small port 4agze and it seems to be in good condition so I guess yours is fine.
ATAl
Postby kingcorolla » Wed Feb 16, 2005 5:36 pm
the only ways to get a bad reading is-
-Not winding enigne over sufficient amount of times. (roughly 10 comp strokes)
-Blowby past the gauge if not held in tight.
-Throttle not wide open.
-maybe if you bought your gauge from supacheap.
-faulty gauge. (see above)
1983 Carina AA63 4age
kingcorolla
Postby ~SlideWays~ » Wed Feb 16, 2005 10:38 pm
Cheers guys, happy to know my engines are healthy :D
~SlideWays~
Users browsing this forum: No registered users and 30 guests
