tyre size
tyre size
Postby Mike- » Wed Feb 16, 2005 11:11 pm
how does different tyre size effect performance
ive got 195/60/15 on my ae101 trueno and found out today im meant to hav 195/55/15 i know it effects speed somehow but cant remember.
does it increase acceleration and lessen top speed or the other way round when going from big to small tyres.
also what size tyres do u guys run on ae101s
any help appreciated
Mike-
Postby Willdat? » Wed Feb 16, 2005 11:28 pm
The affect it has is kinda complicated...basically the change that you're talking about will increase the gearing of the car, so you 'should' be more economical on a long trip, acceleration will probably be decreased it's all a bit academic anyway because the 'indicated speed' also changes...to illustrate my Datsun 1200 could do an indicated 100mph on the original 155 SR 12s, when I upsized to 185 60 14s the indicated top speed dropped to 93mph, to the best of my knowledge this upsize basically removed the optimism that the speedo had from factory...nottoo sure if you get my answer...I'm a little on the rambling side...
Willdat?
Postby solberg Fan » Wed Feb 16, 2005 11:32 pm
Smaller tyres=more acceleration and vice verca. But a small change like that wont be notcable, unless your the man... :o
Team KB' Racing
in association with CRC
1981 DX corolla
*My KE70*
Before you judge someone, you should walk a mile in their shoes. That way, when you judge them, you're a mile away and you have their shoes.
solberg Fan
Postby 2fas4u » Thu Feb 17, 2005 8:59 am
add to that sizes like 195 or 205 or 225 affects your grip on the road. with a rwd like the SW20, i have 205 in the front and 225 in the rear. i think the extra grip gives me better push off.
2fas4u
Postby Caveman » Thu Feb 17, 2005 10:55 am
ae101's run 195/55/15 at the front and 195/60/15 at the rear factory. Unless your running after market mags use these tyre sizes.
Cars use the widest tyres that'll fit. On a FWD its usless having wide tyres on the back and they won't fit on the front due to the small turning radius.
There is very little benifit using smaller tyres over bigger tyres. Smaller tyres allow the engine to turn them easier however the tyre has to displace more to cover the same distance as the larger diameter tyre so very little if any benifit is attained.
AW11 Track Toy
Formerly known as 1998
Caveman
Postby andrew » Thu Feb 17, 2005 3:59 pm
AE101s either come with 195/55/15s all round or 185/60/14s for the lower spec'ed models.
I wouldn't run anything wider than 195s on the factory 15x6" rims. You will get some tramlining with 205s on a 6" wide rim.
Also bear in mind, tyres grip the road by having have weight pushing the contact patch onto the road. The larger the contact patch, the more area the weight has to be spread over and therefore there is less weight pushing the contact patch onto the road; wider tyres only improve grip up to a point. In the wet, a contact patch too big for the car will result in a lot of aquaplaning.
andrew
Postby JT » Thu Feb 17, 2005 4:16 pm
andrew wrote:AE101s either come with 195/55/15s all round or 185/60/14s for the lower spec'ed models.
If you keep the pressure in the tires the same, it doesn't matter what width tires you have, the contact area will always be the same. The advantage of a wider tire is the shape is more of a rectange so when cornering less of the tire comes off the road, breaking is improved due to better heat distribution and normally you run a lower profile so the sidewall has less flex.
JT
Postby andrew » Thu Feb 17, 2005 5:59 pm
JT wrote:If you keep the pressure in the tires the same, it doesn't matter what width tires you have, the contact area will always be the same.
I believe this would depend on the amount of camber and whether we are talking about cornering on the limit of not.
Also, if you compare 195 vs. 205 wide tyres on 6" rims (everything else being equal), the 205 is likely to be a bit balloon'ish (IME anyway). The sidewall will react differently under hard cornering and consequently affect the contact patch.
I think we can agree though, that for a given amount of weight in general a wider tyre will provide more lateral grip only up to a point ? And that tyres vs wheel sizes etc is a complex subject :)
andrew
Postby 2fas4u » Thu Feb 17, 2005 9:53 pm
very complex :?: :?: :?: :lol:
2fas4u
Postby JT » Thu Feb 17, 2005 11:19 pm
andrew wrote:I believe this would depend on the amount of camber and whether we are talking about cornering on the limit of not.
I think the area will still be the same regardless of camber; area=weight/pressure and weight and pressure are the same which means it will just have a more trapezium shape than rectangle. Yes, I'll argee with you on the other points.
The original post was what would happen if he went from 195/60/15 to 195/55/15. The answer is, you will notice (or not) a small increase in acceleration and your geared top speed will be lower (not that a standard 20V will reach it's geared top speed)
JT
