peas wrote:Yeah thats what I thought... whats the go on fitting the 20b? I have been told that its goin to bolt straight up with the exception of one stud! That just sounds way too easy to be true.
Twolitre wrote:You can use a ct20b on an st185 with the stock downpipe, or aftermarket, you can also use a ct26 on an st205 with either and yes the turbo bolts straight on, you just need to use the existing oil and water feeds from your ct26, finding one however is not easy.
The stock top mount IC is crap, if you must keep it at least put a fan on it, otherwise front mount and put up with the lag or go water-air off an RC
Users browsing this forum: Bing [Bot] and 73 guests
