Chickenman wrote:One of the most promising Ideas I've seen is the CO2 intercooler rings, a few squirts and you got cold I/C. The pipes are in constant contact with the I/C as well... *goes to find where I saw it*
Rollux wrote:If the air entering the turbo is significantly cooler than ambient, and you have a nice efficient turbo, your intercooler could become an interwarmer, or pointless
JiNX wrote:
Hottest I've ever felt was a guy running a high-pressure intank pump, freeflowing into a surge tank, which was feeding another high pressure pump, by the time the fuel had run through the system, the surge tank was literally too hot to touch!
kingcorolla wrote:Also should the fuel return always be plumbed to the tank? What about plumbing to the surge? The only con i can think of with this is returning hot fuel to your system, but how significant would the heat differential be between the two options? Also would the fuel being delivered to the surge counter-act with the return pressure and force its way up the return??
vvega wrote:oh and just for the record 5 dgrees drop at the intake might drop you 1 degree at the outlet of the turbothe heat is made buy the pressure that is been held in the intake
more pressure = more resistance
and we all know that resistance generates heat
JiNX wrote:
Only problem is the waste co2 gas then gets sucked into the motor...
Users browsing this forum: No registered users and 61 guests
