ae85 rear disk brake conversion
Postby panda_dan » Wed Feb 23, 2005 10:06 am
can anyone give me some help on this one? i am in the process of converting the drums on my ae85 to ae86 disk brakes. before i get all greasy, if anyone has done this before can you give me some pointers on what im in for? ta
panda_dan
Postby thaphatty » Wed Feb 23, 2005 10:22 am
huh what do you mean?
coverting from a S series diff to a T series?
or wacking discs on a S series diff (lol)
t series diff coversions pretty easy, just remeber to gut the brake proportioning valve at the rear before you go for a drive
how far through the process are you?
thaphatty
Postby Stealer Of Souls » Wed Feb 23, 2005 11:36 am
Easiest way is to just get a rear end from a AE86 or TE71... Then it's a bolt off bolt on job. But you should make sure to get the master cylinder, proportioning valve, and handbrake cables from the donor.
'86 AE85.5 Levin
Stealer Of Souls
Postby spencer » Wed Feb 23, 2005 1:49 pm
master cylinder is the same
ms63 crown
spencer
thanks
Postby panda_dan » Wed Feb 23, 2005 3:17 pm
yeah i have a locked s series diff on the car and have some 86 rear disc brakes lying around thought i might as well chuck them on. its just an intermediate step while i save for hilux diff. it will also it will be a good learning curve as i will be putting s13 brakes on the hilux diff and will have to do the same job again, so its good practise.
panda_dan
Postby JamesM » Thu Feb 24, 2005 12:18 pm
lol.. u hardout
Team Megasquirt
1984 AE86
180kW, 600Nm@wheels @ 16.5psi
JamesM
