Can ne 1 recomend a turbo for a '89 gt4 celica
Postby explosiv » Sun Feb 27, 2005 5:40 pm
im wondering if n e 1 could recomend a turbo that would b an ideal upgrade for a '89 gt4 cleca...also include information on n e eingine alterations that may need to b done
cheers, >>eXpLoSiV<<
explosiv
Postby flygt4 » Sun Feb 27, 2005 5:42 pm
ct20b off st205 and later model mr2's...
flygt4
Postby explosiv » Sun Feb 27, 2005 6:23 pm
would a t3/t4 go on with minimal to no alterations
explosiv
Postby Dell'Orto » Sun Feb 27, 2005 6:26 pm
No, the flange is completely different. The CT20B is the only different turbo that will bolt right up. The other option is a highflowed version of your current turbo.
Re: Can ne 1 recomend a turbo for a '89 gt4 celica
Postby Bling » Sun Feb 27, 2005 6:47 pm
explosiv wrote:im wondering if n e 1 could recomend a turbo that would b an ideal upgrade for a '89 gt4 cleca...also include information on n e eingine alterations that may need to b done
off topic i know, but in all seriousness, why do you have to talk like u sent this message as a txt from your cellphone? :?
Postby explosiv » Sun Feb 27, 2005 6:52 pm
its jus quiker and easier to type shorthand...
how much boost does a ct20b give off...i am hoping for around 20-30psi
also how much boost does an '89 gt4 hav standard and how high can they b wound up up with boost tap..
explosiv
Postby peas » Sun Feb 27, 2005 7:03 pm
Ummm your Celica will be running at appro 8 psi at the moment and you need more than just a turbo to get 20-30psi (which is a huge range in itself). Check out the latest Fast Fours for a mad 3S-GTE in the GP & Gizzmo MR2. That might give you some idea of what else you might want to consider before "winding up the boost"
'97 Caldina GT (ST215G)
peas
Postby matt dunn » Sun Feb 27, 2005 8:35 pm
explosiv wrote:how high can they b wound up up with boost tap..
To about 1/2 of what you want if you want 30psi.
Much more than 15psi and you'll need to do a whole lot of other stuff too,
( if you want it to last for long)
Postby Al » Sun Feb 27, 2005 8:49 pm
Other bolt on turbos are the power enterprise pe1919 and the blitz k1 380v
Both retail for around twice what a new ct20b will cost you.
Al
Postby _will_ » Sun Feb 27, 2005 9:11 pm
How much do the ct20b's sell for? (ballpark figure)
Celica GT-Four ST185
Starlet KP61
http://toyspeed.blakjak.net/profiles/profile.php?id=1304
I don't always not make no sense
_will_
Postby explosiv » Sun Feb 27, 2005 9:51 pm
theres a ct20 on trademe.co.nz for $120
http://www.trademe.co.nz/Trade-Me-Motor ... 925256.htm
explosiv
Postby Al » Sun Feb 27, 2005 9:53 pm
Totally different turbo. ct20 and ct20b are completely different, you will struggle to even find a used ct20b. Let alone one for $120.
_will_ you have pm for the price.
Al
Postby flygt4 » Sun Feb 27, 2005 9:54 pm
slight difference between a ct20 and a ct20b.... :wink: new ct20b think sumwhere over a grand... 2nd hand ct20b if u can find one...7-800
flygt4
Postby explosiv » Sun Feb 27, 2005 9:59 pm
how much pounds of boost would u get out of a ct20b turbo strapped onto a celica engine?
explosiv
Postby explosiv » Sun Feb 27, 2005 10:00 pm
also are ct20b's ball bearing turbos or not
explosiv
Postby Al » Sun Feb 27, 2005 10:05 pm
explosiv wrote:how much pounds of boost would u get out of a ct20b turbo strapped onto a celica engine?
thats totally up to what you set your boost controller to
with my boost controller turned off (actuator controlling boost) i get 8psi
explosiv wrote:also are ct20b's ball bearing turbos or not
nope
Al
Postby explosiv » Sun Feb 27, 2005 10:07 pm
yea but how high can u wind it b4 it will b in self destruct mode
explosiv
Postby Al » Sun Feb 27, 2005 10:17 pm
Ceramic turbine ones are a bit of a lottery, some people have them break just after 1 bar, and people like me have cranked out 1.25 bar regularly on the drag strip without issues.
Mr Revhead off these boards will sell you a new ct20b with a steel turbine that will undoubtably have more longevity than a ceramic, albeit slightly laggier. Its a good turbo if you want to max out your stock fuel system. If you want more than that and have the dollars $$$$ to spend look for something larger.
Al
Postby explosiv » Sun Feb 27, 2005 10:23 pm
how much do u think he will sell it for..also do u think he'll hold onto it for a while for me
explosiv
Postby Dell'Orto » Sun Feb 27, 2005 10:26 pm
I believe they go for about $1600, and as Mr Revhead works for Toyota, he can get them at any time.
