ok
st205 1996
mods: cold air bos, replumbed BOV, apexi superflow filter, battery to boot to put the pod straight to the side with less than 1.5 feet of pipe (3 inch)
i also have a hks 3 inch cat back
i went on the dyno, no other mods and i got 164.8 KW at the wheels and has reached a peak boost 13.8psi, though the boost curve was highly eratic...it had a boost average of bout 12.8 jsut out of estimation and self calculation..
now my AF ratio was 10.8, these cars run rich!!
now as far as i know, rich means it will prevent detonation at slightly high boost, which means i have a margin on more boost...is that correct or wrong?
also, i am planning on gettign a elec boost controller by g-reddy, but i want to know, when i do take it to the track, what is the safe level of highest boost i can put on it, i mean what can the engine handle in terms of highest boost and what can the ceramic turbo handle safely, cos im sure there are two limits we must take into considerations here...
i was thinking of doin the high boost settign flat o0n 1 bar, and i was thinking of doing the low on standard which is about 12.5psi...
please feedback and comments....gt4 owners...GT4 ICHI BAN!!!!!!!!
