272 degree cams
272 degree cams
Postby trdfxgt » Wed Mar 09, 2005 11:07 am
hi im getting some 272 cams for my fxgt race car i have got franklin cams re grinding my originals and extending the valves my question is about the set up i want some ajustible cam gears which i think iv found some good ones what i need to know is will i need a new feul pressure reg ? and what sort of performace gains should i get from this
trdfxgt
Postby thaphatty » Wed Mar 09, 2005 11:18 am
is this dominic by any chance?
what you'll need is a decent computer to get the most out of them.
thaphatty
Postby trdfxgt » Wed Mar 09, 2005 12:12 pm
dominic haha na its not 272 is ment to be max for standed computer according to franklin and they have done alot so there must be someone out there who has done this and knows a little about what i should expect also this is a car that needs to be relaiable i dont wants heaps of hp it seems quick even standed doing 50sec laps of taupo with no mods and air cond ha ha
trdfxgt
Postby ChaosAD » Wed Mar 09, 2005 6:01 pm
Ya could get an apexi S-AFC. go for about $300 - $400 second hand.
Or if your any good soldering, you could get a 'MegaSquirt' programmable ECU kitset.
ChaosAD
Postby AceSniper » Wed Mar 09, 2005 7:05 pm
I got a SAFC Ver1. if ur intrested but its no good for a silvertop (why i needa sell :P ) Pm me for info
AceSniper
Postby trdfxgt » Wed Mar 09, 2005 7:32 pm
[quote="ChaosAD"]Ya could get an apexi S-AFC. go for about $300 - $400 second hand.
Or if your any good soldering, you could get a 'MegaSquirt' programmable ECU kitset.[/quote]
what is that ?
trdfxgt
Postby RedMist » Wed Mar 09, 2005 7:55 pm
Research it for at least a month before biting the bullet. Or attempt to get as much help from a local Megasquirt support group.
http://www.megasquirt.info/
http://www.msefi.com/index.php
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby trdfxgt » Thu Mar 10, 2005 1:18 pm
ok ill look into these things has anyone done these mods and have an idea of the power increase?
trdfxgt
Postby dubious » Thu Mar 10, 2005 7:17 pm
is the version 1 the non digital version? why are they no good for silvertop?
dubious
Postby AceSniper » Thu Mar 10, 2005 7:28 pm
yea its the one with the 5knobs, no good for silvertop... coz they dont work on "Flap Type AFM's" work on most other things tho, inc blacktop
AceSniper
Postby 85AW20v » Thu Mar 10, 2005 8:22 pm
So if you convert the silvertop to MAP with bluetop sensors it would work OK?
See ya
Simon
85 MR2 20v
85AW20v
Postby vvega » Thu Mar 10, 2005 8:24 pm
Simon85MR220v wrote:So if you convert the silvertop to MAP with bluetop sensors it would work OK?
nope simply because your ignition triggers are compleatly different
v
vvega
Postby AceSniper » Fri Mar 11, 2005 1:01 pm
only way u could run it on a silvertop is aftermarket ecu (no point using it then) or if you use a blacktop ECU and loom.
But from what iv read the SAFC2 will work on a silvertop (2nd ver digital one) but they are around $5-600
AceSniper
Postby trdfxgt » Fri Mar 11, 2005 4:34 pm
ha ha guys i want to know about cams and hp ha ha but sweet as though
trdfxgt
Postby trdfxgt » Fri Mar 11, 2005 5:09 pm
trdfxgt
Postby Jebus » Mon Mar 14, 2005 11:37 am
Can any gains be made by using an SAFC Gen 1 on stock motor (minus intake and exhaust mods) ???
Jebus
Postby sergei » Mon Mar 14, 2005 10:35 pm
I'm using SAFC (1) on my silvertop, and, no gains are so minimal, but you can fix lean out problem in mid range, so it will feel nicer... that about it..
SAFC will run on AFM.
Postby AceSniper » Tue Mar 15, 2005 8:41 am
sergei :
what setting do you have it on at the back of the unit? as you can use 1gg but since its a 6cyl AFM the rpm marks on the afc are wrong.
AceSniper
Users browsing this forum: No registered users and 29 guests
