How much turbo shaft play is too much?
Postby ~SlideWays~ » Thu Mar 10, 2005 11:32 pm
Im new to turbo's, ive just removed mine and it has a lil play but it doesnt smoke (anymore... lol).
Its a t25g, are there any sort of "safe" limits? ie should it have play when new and how much is too much.
Thanks in advance.
~SlideWays~
Postby Akane » Fri Mar 11, 2005 12:35 am
0.18mm up/down
0.13mm in/out
(Those specs is for CT26, but should be pretty much around that ballpark)
Postby Lloyd » Fri Mar 11, 2005 6:32 pm
Shouldn't really be any in/out at all. You'd expect a little up and down which in most cases the oil would take that up (depending how much play there is)
Postby vvega » Fri Mar 11, 2005 7:51 pm
generally if you can feel thrust(end to end movement) its warn
and side to side is hard to tell specailly if the oil has drained out of the turbo
v
v
vvega
Users browsing this forum: No registered users and 29 guests
