"Best" oil to use in 4AGEs
Postby Stealer Of Souls » Fri Mar 11, 2005 10:32 am
Okay, I want to specifically know what grades I should be using in my Blue top. But I'm sure that people would like to hear about other 4AGEs too.
At the moment I'm using 10W40 (semi-synth). But was looking at some 5W30 (full synth) as the price was quite similar.
'86 AE85.5 Levin
Stealer Of Souls
Postby Ae92typeX » Fri Mar 11, 2005 12:08 pm
I used to use about 10-40 no synth in mine when I had it for 6 years. only used about 500ml between 5000km changes and never had an issue with the engine.
Once more people have put discussion into this it should go to FAQ section I think as it comes up fairly often... :D
Ae92typeX
Postby strap-on » Fri Mar 11, 2005 12:11 pm
i know with 20v's you cant put anything lighter than 10/40 in them as they burn it, i found it ran best on 20/50 redline lol but not everyone can afford that, now im finding 10/40 magnatec is a mint oil
strap-on
Postby Dodgy Guy » Fri Mar 11, 2005 2:25 pm
i run my 20v 4age on 10w40 magnitec - i use hardley any and it stays pretty clean too
Dodgy Guy
Postby JT » Fri Mar 11, 2005 3:53 pm
I've been running 15W-40 Castrol GTX Protec but only because that's what the previous owner was using. That and it was leaking and using a bit so I thought it was a good middle of the road option. Now with winter coming and fixing the leaks I'll probably go to a 10w-40 Valvoline semi-synth.
The other thing to remember is the grade of oil too, this is just as important as the viscosity. The page here is a good read: http://www.chris-longhurst.com/carbible ... bible.html
JT
Postby Alex B » Fri Mar 11, 2005 5:35 pm
castrol recons CASTROL GTX or CASTROL GTX PROTEC 15W-40 (3L)
http://www.castrol.com/castrol/generics ... Id=6007486
go to the bit that says product recommendations bloody useful most cars on their i think
Postby LEV_101 » Fri Mar 11, 2005 9:20 pm
im running mobil 1 5-w50 full-synth on my 20v. bit expensive but super good! heard it burns out the oil due to its thin but yea ... still good !
LEV_101
Postby Lloyd » Fri Mar 11, 2005 9:25 pm
Mosts oils wont make a difference, middle-of-the-road standard 15W40 should be all you need unless you've got some big mods. GTX2 Protec 15W40 in mine, probably just cause thats what we use at work on the majority of cars
Postby EVLGTZ » Sat Mar 12, 2005 11:05 am
Use Penrite in my 4AGTE. Seems all good so far (first time trying it and oils still nice and clean after a months use)
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby MacrosSiR » Sat Mar 12, 2005 12:22 pm
Valvoline vr1 :)
You even get a free oddly shaped hat.
MacrosSiR
Postby yobbosayo » Sat Mar 12, 2005 8:01 pm
using Mobil super XHP 15-40 in my bluetop.
I'm with the guy who says just use a good middle of the range oil. Super XHP was about $24 from memory.
I figure the bluetop was designed in 1982 or 1983, so any modern oil has got to be way better than the oil which was originally specified
yobbosayo
Postby Stealer Of Souls » Mon Mar 14, 2005 8:11 am
So what's the factory "recommend" rating?
I'm using Magnatec for the oil gripping metal part of it. Gotta be good for ya engine I reckon.
'86 AE85.5 Levin
Stealer Of Souls
Postby sergei » Mon Mar 14, 2005 8:15 am
Castrol R 10W60 Full synthetic. The best oil for a 20v (or any other car)
Postby Ae92typeX » Mon Mar 14, 2005 8:34 am
I also look at the API rating of the oils. I usually buy SJ. For a 4age, I never went below SF, which was still of a much higher standard than when the 16v's came out many moons ago.
Currently I think the latest ratings are SL (for spark engines) and CI-4 (for compression engines- i.e diesel)
If you go to places that sell cheap as oil, like $10 for 4+ litres and look at the rating some are as low as SG, which is way out of date.
Ae92typeX
Postby Stealer Of Souls » Mon Mar 14, 2005 9:48 am
The Castrol range (which I use) is mostly SJ/CF so I've tended to not worry.
Was looking at some Castrol Forumla R cause of the small price difference between the entry grade Formula R and Magnatec...
'86 AE85.5 Levin
Stealer Of Souls
Postby Pelo » Mon Mar 14, 2005 11:14 am
According to the manual factory recomendation is for "10W-30 to 20W-50 SF/CC or better" grade, for normal new zealand temperatures 10W-something is fine.
I have used 10W-40 magnatec in all my cars with 3000km oil AND filter changes, 100% clean and uses no oil at all.
Apart from my old MR2 SC which I put 5W-50 pennzoil in but that's too expensive.
Pelo
Postby Pelo » Mon Mar 14, 2005 11:19 am
Stealer Of Souls wrote:So what's the factory "recommend" rating?
The "unique molecular attraction" etc. blurb on the oil packs is the male equivalent of the stuff they write on "anti-ageing" creams and "look ten years younger with BOSWELOX!" "make your hair even shinier than with our last product!" etc, marketing BS lol!
Nice to think you are putting something good into your engine though... my mate reckons he can drink synthetics they are just soooo goooood :wink:
Pelo
Postby Stealer Of Souls » Mon Mar 14, 2005 11:58 am
Now there's a good experiment...
Dip a metal rod in to magnetec, another into "normal" oil (protec?), and a third into motor up or X1R. Hang them all up and check back ever few hours to see what's happening...
Must start this experiment. Maybe when i get home...
'86 AE85.5 Levin
Stealer Of Souls
