3tgte turbo upgrade
3tgte turbo upgrade
Postby 5extoy » Mon Mar 14, 2005 7:25 pm
what turbos have people put on these engines??
im still running tha standard turbs and it runs out of puff pretty early.
ke 35 3tgte.
5extoy
Postby slonlo » Mon Mar 14, 2005 8:02 pm
got a T03 off a skyline on mine
its got a flange welded to the origanal manifold to make it fit
and some custom water and oil lines
havent had any problems with the set up yet
'89 LiteACE van
slonlo
Postby YeMs » Mon Mar 14, 2005 9:53 pm
howsit james. the turbos off the RB series motors are an easy upgrade. easy to source. im going to run the t4 off an rb25det, apparently the perfect upgrade. am getting a custom exhaust manifold made up and am gunna top mount the turbo and run about 10-12psi, which should b like running 18ish on the ct20. the ct20's are a shit turbo, they do $&#$% all an run off puff quite quickly, especially with them running abit more than standard boost.
Your local Hybrid Elite tech
YeMs
Postby RS13 » Mon Mar 14, 2005 10:54 pm
Would a CT26 bolt up? CT20B?
RS13
