Jebus wrote:EFI sytems need constant high fuel pressure, as you say when youre going round with very little fuel in your tank its sloshing too much and you arent getting a constant supply. A surge tank is a round cylinder 1L - 2L in capacity which when fuel is pumped to the engine it goes through the surge tank. The surge tank is only small so the fuel sits in the bottom of it and cant move around when you go around corners, this will stop the problem. But as far as im aware you need to run two fuel pumps, one to feed the surge tank and one to sed fuel from the surge to the engine. Only way to fix your prob at the moment is to have more than 1/2 gas in the car, unless its another issue like fuel filter??
Its fukcing hard to explain in writing but hope that gives you an idea. Im in the process of making one for my car.
Jebus wrote:thatd be sweet callum, or would I be better off doing the surge tank thing considering the parts ive already got, ive got a Commodore Hi pressure electric fuel pump, a Celica high pressure electric pump and a K series low pressure electric. Also a mate of mine who is an engineer is getting round to building me one shortly.
what do ya reckon?
TRDmod wrote:i would rather rot in the deepest holes of hell that go to quest 4, they are the most unprofessional through my experience and just give half assssed answers, no offence if you are friends iwth them...i would rather go somewhere else, but thanks, i wanted ot know if i need cert and warant, so thats good, ill get them
thanks guys
Users browsing this forum: Google [Bot] and 26 guests
