4A-E missing
4A-E missing
Postby Pelo » Wed Mar 23, 2005 8:07 pm
I have an 85 corolla with a 4A-ELU engine, recently it has randomly been missing violently.
Usually under light or no throttle, it will jerk and jump and the tacho will jump up and down. All my leads/plugs are fine, its not fuel surge. I was thinking maybe the MAP sensor or a vacuum leak?
It is getting worse and really annoying!
Pelo
Postby CozmoNz » Wed Mar 23, 2005 8:09 pm
what about dizzy?
Rayne For President!
CozmoNz
Postby Pelo » Mon Mar 28, 2005 11:54 pm
Arghh I hate cars sometimes! I figured that yes it might be the dizzy, so the ONLY thing I did was take the cap off, degrease and sand the terminals slightly and sand/clean the rotor very slightly.
Put the cap back on and it WILL NOT START at all! Cranks, has fuel+air, HT leads spark to earth, and correct firing order. Tried for 3 hours to figure it out today and now I am without a car :cry: HELP any ideas???
Pelo
Postby Pelo » Tue Mar 29, 2005 10:23 pm
Anyone... <echo> <echo> ?
Pelo
Postby CAMB01 » Tue Mar 29, 2005 11:26 pm
check ya engine earths, mine had the same symptons, turned out it was just a loose engine earth
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
