ke20 chassis q
ke20 chassis q
Postby Tablets » Fri Mar 25, 2005 1:48 pm
just wondering, approximately how much power/torque can a ke20 chassis handle without bending and without chassis modification?
i know it would vary depending on condition of the chassis in the first place but assuming the one in question is original 90000 miles and garaged all its life...
plays a big part in my friends upcoming repower, i want him to go 1uz but he doesnt think it will fit and is worried about the chassis getting bent all ass about tit
umm yea cheers
Tablets
Postby l1ttle_d3vil » Fri Mar 25, 2005 5:01 pm
not sure what sort of power difference there is between a 1uz and a 4agte, but i've seen turboed 4age 16v in a ke35 and the chassis has been cracked/twisted from the power. (not sure what sort of kw it puts out but it'll keep up with sti's etc)
Postby NZ_AE86 » Fri Mar 25, 2005 6:18 pm
Yeah I have also seen chassis cracking and twisting from a 20V Turbo conversion!
NZ_AE86
Postby wde_bdy » Fri Mar 25, 2005 6:42 pm
http://www.1uzfe.com/
Don't like how he did his engine mounts though.
Callum
wde_bdy
Postby Logan » Sat Mar 26, 2005 9:16 am
Ive seen a mild 4k twist a kp60's chassis on the race track...came apart at the seams....
SR Sold. Onto Other Things
Logan
chassis
Postby KE20 » Sat Mar 26, 2005 6:51 pm
i had a 3sgte in my ke20 and i split 3 fuel tanks from the car twisting. they split in the middle of the tank behind the seat, only about an inch long,in the end i just started welding them up. a 1uzfe will fit as i measured one up, but a cage might be a good idea. also i found out that when the ke20 series cars were being assembled in thames, toyota used a second hand spot welder. ive had the tow hook pull right out of the chassis. also when the ke30 series were getting build toyota had a new welder but toyota japan changed the way the treated the steel and didnt tell nz till ke70's etc, so thats why you get rust patches in the middle of a mint panels, as toyota nz were untreating (or something likethat)the panels the same as ke20's for painting.
KE20
Users browsing this forum: Bing [Bot] and 24 guests
