hellp
hellp
Postby macabre » Sun Mar 27, 2005 10:43 am
Hey fellas i have a problem with my ignition i think, if i start my van it wont run unless i keep the key half turned between where it engages the starter motor and the rest position that it returns to after starting, i guess its the ignition itself although could it be the imobiliser?? I tried to hot wire it to see if it could be bypassed but im too noob. I should only have to link three wires aye the ign lights to power then the starting wire to power untill it starts? and also how the $&#$% do u get the ign off exactly? spanks very much :P
237rwkw, all go no $&#$% show!
macabre
Postby Zak » Sun Mar 27, 2005 6:06 pm
check your main fuses, as that happened to my corolla, the car lost ignition if you turned the key too far. It did make the car hard to start for preople that shouldn't be starting it though :lol:
Zak
Postby kingcorolla » Sun Mar 27, 2005 7:02 pm
faulty ballast resister
1983 Carina AA63 4age
kingcorolla
Postby macabre » Tue Mar 29, 2005 6:37 pm
fixed it it was the ignition!
macabre
