5mge cambelt replacement
Postby deaf_rattle » Sun Mar 27, 2005 11:18 pm
Removal
1. Remove timing belt covers.
2. Rotate engine clockwise until the timing marks are aligned as per the diagram.
3. Remove the tensioner and spring.
Measure the tensioner spring free length.
Spring Free Length 69mm.
4. Remove timing belt.
Installation
1. Timing marks must be aligned.
2. Fit the tensioner and spring.
3. Lever the tensioner away from the belt and tighten the tensioner locking bolt.
4. Fit the timing belt in this order:
Camshaft 1
Camshaft 2
Auxiliary
Crankshaft
Tensioner.
5. Loosen tensioner bolt.
6. Rotate engine clockwise, two revolutions to #1 TDC compression stroke.
7. Check timing marks are aligned.
8. Tighten tensioner locking bolt.
9. Make sure the belt tension is equal between "A" & "B" (on diagram).
Tightening Torques
Camshaft Gear bolts.
69Nm
Crankshaft Bolt.
216Nm
Front Cover Bolts.
10Nm
Tensioner Bolt.
49Nm
Auxiliary Pulley Bolt.
22Nm
R&R Time
2.2 hours (add 0.5 hours for air conditioning)
Postby ee904age » Mon Mar 28, 2005 12:04 am
Looks like Im not the only one with alot of time on my hands today!!! :lol: :lol:
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
