Anybody feel like shairing their 20v map?!? :-)
Postby tommi20v » Fri Apr 01, 2005 6:05 am
Hi all!
So, my story is this... there is about a year now since I did a 20v silvertop swap on my 1995 corolla. I installed a Wolf 3D ecu along with it and ever since I went for my first spin, I have been trying my best to to the fuel and ignition map before spending an arm and a leg on the dynoshop.
So far so good but I was wondering if ANY generous soul would like to share their 20v map with me so I could see where I stand and also so I could be quicker on the dyno when I go.
Thanks in advance!
Tomas
www.20v4age.com
tommi20v
Postby RedMist » Fri Apr 01, 2005 7:09 am
I could post one of my old silvertop maps... but it will be useless to you. I run Link.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby tommi20v » Fri Apr 01, 2005 11:11 am
I am not realy thinking about finding a fully usable map for my car, only something to compare to mine, so the Link map would be ok. After all I should be able to read something out of your fuel and ignition points.
Thanks!
Tomas
www.20v4age.com
tommi20v
Postby RedMist » Fri Apr 01, 2005 1:43 pm
LINK ENGINE MANAGEMENT
MISCELLANEOUS TPS WASTEGATE
CLMP MAST R.LIM M.LIM A.LIM MODE CYCL VOLT RPM TEMP LOW HIGH
39 40 85 15 38 5 4 13 3800 90 0 11 0 0 0 0
0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
COLD START TRANSIENT LAMBDA
12 5 8 0 1 2 4 5 9 10 74 78 81 84 87 89
16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
RPM x 1,000 MAP (kPa)
ZONE FUEL
0 1000 2000 3000 4000 5000 6000 7000
BAR 34 32 33 33 33 37 39 37 39 37 38 39 39 39 39 39
0.4 100 105 110 115 120 125 130 135 140 145 150 155 160 165 170 175
34 32 37 39 39 38 38 39 40 44 44 44 44 44 44 44
0.8 200 205 210 215 220 225 230 235 240 245 250 255 260 265 270 275
35 29 29 30 30 33 34 33 38 36 36 38 37 39 42 42
1.2 300 305 310 315 320 325 330 335 340 345 350 355 360 365 370 275
33 34 37 30 40 40 41 42 43 43 43 43 46 46 46
1.6 400 405 410 415 420 425 430 435 440 445 450 455 460 465 470 475
37 39 39 39 39 40 41 44 44 45 46 47 47 48 48 48
2 500 505 510 515 520 525 530 535 540 545 550 555 560 565 570 575
35 36 37 38 39 41 41 44 46 46 46 47 47 47 47 47
600 605 610 615 620 625 630 635 640 645 650 655 660 665 670 675
ZONE IGNITION
BAR 0 29 45 29 29 27 27 27 27 27 27 27 27 27 27 27
32 41 30 26 33 33 32 29 30 30 32 32 35 32 32 39
28 29 29 28 30 32 31 31 32 33 33 29 27 29 25 29
29 29 25 29 29 29 30 31 31 29 32 31 31 30 34 31
26 28 29 27 28 29 28 29 32 32 31 30 31 32 30 25
25 28 28 26 26 26 26 26 28 29 30 27 30 28 26 27
RedMist
Postby suberimakuri » Mon Apr 04, 2005 8:44 am
my 3sge fuel map is on the gd website under the 3sge into aa60 article
suberimakuri
Users browsing this forum: Bing [Bot], Google [Bot] and 6 guests
