rules for making Intake manifold?
Postby Liloss » Fri Apr 01, 2005 10:35 pm
going to make a custom intake manifold....Just wondering what design tips are out there, is there any real rules/guides to follow?
It's going on a boosted application...
Liloss
Postby blitza » Fri Apr 01, 2005 10:41 pm
there are a few books on the topic, corky bell's maximum boost covers it fairly well from a broad perspective, is a good place to start.
MAD Industries Limited
blitza
Postby craigt » Sun Apr 03, 2005 11:58 pm
Depends on what you want to build, you might want single throttle, large plenum, long tapered runners. or you might want quad throttles, short runner etc. So many different variables. Im building a quad throttle setup for my 4AGTE, very short runners (32mm) in the manifold, 12-15 cm ramtubes into a 4 litre plenum.
pm Redmist, he might be able to point you in the right direction
If it doesn't fit, force it.
If it breaks it needed replacing anyway!
AE101 4AGZE
KP60 4AGTE project
craigt
Postby Liloss » Tue Apr 05, 2005 9:15 pm
well i doont want quads as its going on a V6 3vz. Whats the effect of short runners? and whats best for a turbo setup?
i was thinking of designing one like on a vg nissan engines, in a U shape with the TB on one end of the U and the runners running straight down to the inlet valves.
what should the intake manifold be made from?
thanks
~~Liloss~~
Liloss
Postby Akane » Thu Apr 07, 2005 1:34 am
Short runners for high RPM power, longer runners for low down torque.
don't make the runners too big you want more velocity for a NA
Hope that helps.
Users browsing this forum: No registered users and 41 guests
