4age carbies
4age carbies
Postby smitty21 » Fri Apr 01, 2005 11:51 pm
hey, im putting a set of twin weber carbies on my 4age redtop which i have pulled the TVIS off. Wot sort of power does the Redtop put out TVIS version? Also does anyone know where i can get a intake manifold to fit twin weber carbies from, wether i get a set made up or brought?
smitty21
Postby Dell'Orto » Fri Apr 01, 2005 11:53 pm
Yes, Redline make a twin sidedraught manifold for them, use twin 40DCOE's :D or 45's if you're going for big cams
Postby NZ_AE86 » Sat Apr 02, 2005 9:26 am
So you have the EFI and you are removing it to put carbs on?? If so why?
NZ_AE86
Postby RedMist » Sat Apr 02, 2005 9:46 am
Palmside (CHCH) also have a manifold.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Dell'Orto » Sat Apr 02, 2005 11:54 am
NZ_AE86 wrote:So you have the EFI and you are removing it to put carbs on?? If so why?
Have you heard a 4AG with big twin sidies before? Very cool :D
Possibly to make it easier to install in an old school KE?
Postby NZ_AE86 » Sat Apr 02, 2005 11:53 pm
May sound cool but if you want fuel economy, power over a wide rev range, consistant cold and hot starting, reliablility etc etc etc!
If that is what he is after sure go for it but they are a pain in the ass!
NZ_AE86
Postby solberg Fan » Sun Apr 03, 2005 1:30 am
NZ_AE86 wrote: they are a pain in the ass!
Yes,.......... yes they are :evil:.
But if you want to make it a bit diffrent, go for it.
Team KB' Racing
in association with CRC
1981 DX corolla
*My KE70*
Before you judge someone, you should walk a mile in their shoes. That way, when you judge them, you're a mile away and you have their shoes.
solberg Fan
Postby craigt » Sun Apr 03, 2005 2:02 pm
Otherwise try this place for a manifold, here they are quite good to deal with. They are in South Africa, they have an impressive list of sidedraught manifolds for many engines, including heaps of Toyotas
If it doesn't fit, force it.
If it breaks it needed replacing anyway!
AE101 4AGZE
KP60 4AGTE project
craigt
Users browsing this forum: Bing [Bot] and 6 guests
