How to tell if the thermostat opens?
Postby ThoughT ExperimenTs » Sat Apr 02, 2005 10:24 am
"With engine cold, remove radiator cap. Start car and watch the fluid level at radiator opening. When engine warms up the thermostat opens and the water level goes down because it's being released through the thermostat to circulate and cool the motor."
Is that right?
I thought I coudl just wait and see if the fan goes on?
ThoughT ExperimenTs
Postby ThoughT ExperimenTs » Sat Apr 02, 2005 10:26 am
I left it for a few mins and came back and a lot had come out from where the cap is ment to be, it kept going up in down, I GUESS that means the thermostst works? Now just waiting for the fan.
ThoughT ExperimenTs
Postby strap-on » Sat Apr 02, 2005 10:28 am
best way to do it is ull out your thermostat, and test in in hot water with a thermometer, check if its opening when its supposed to ( most thermoststas have the temp, stamped on the side)
strap-on
Postby dragg_racer666 » Sat Apr 02, 2005 10:29 am
take out your thermostat mate.
boil some water and then drop your thermostat in the boiling water. the water is very hot so the heat will make the thermostat open. if it dosn't open then it's buggered
dragg_racer666
Postby vvega » Sat Apr 02, 2005 10:29 am
soiulnds like you have a airlock ....it will pass
kepp adding water as it needs it
v
vvega
Postby ThoughT ExperimenTs » Sat Apr 02, 2005 10:31 am
well shit I didn;t keep adding water and I put the cap on and let it just sit there ideling, the engine temp gauge went jut over 3 quarters up and the fan still didn't go on? Please tell me that's because there isn't enough water?
ThoughT ExperimenTs
Postby ThoughT ExperimenTs » Sat Apr 02, 2005 10:42 am
Sorry for the compleate newbie questiosn and panic. But I don't think the thermostat did ever open because the top tube was hotter then the bottem tube, the bottem tube was cold. I guess the engine only heated up because i didn't keep toping it up with water as it passed out all that air. The Fan I'm not really too sure about, maybe that's decided by the thermostat, and the radiator wasn't hot enough?
ThoughT ExperimenTs
Postby vvega » Sat Apr 02, 2005 10:53 am
the bottom tube is water going into the engine the top tube is water comming out
if the bottom tube is cold the fan wont kick in and this as around where the thermoswitch is..
v
vvega
Postby ThoughT ExperimenTs » Sat Apr 02, 2005 11:00 am
I can't just keep topping up the water as it blurts it out, it just does big blurps and I can't put enough in, so I put the cap on again, the engine temp went 3 quarters up no fan came on, so i had to turn it all off again.
The thermoswitch is on the top tube, where the heater tubes are ment to connect.
3SFE engine, if that helps.
Somethings wrong.
ThoughT ExperimenTs
Postby vvega » Sat Apr 02, 2005 11:03 am
no nothing wrong you just have a airlock
turn the carr off and add water for a bit
wten restart the car
airpockets are comon for a modern car best to have a proper rad filling vacume unit
great for this kind of isssue :D
v
vvega
Postby Mr Revhead » Sat Apr 02, 2005 11:05 am
you could try draining it and adding water slowly.....
i always run them with the cap off for a bit, then put it on drive round the block park it and let it cool the check. im paranoid so i always check the water (when cold) everyday fo rthe next couple.
Postby ThoughT ExperimenTs » Sat Apr 02, 2005 11:06 am
car is on a very slight slope - sloping backwards, should I jack it up a bit?
*waits for the engine to cool down again.*
ThoughT ExperimenTs
Postby Mr Revhead » Sat Apr 02, 2005 11:09 am
what kind of car is it?
that shouldnt matter too much
Postby ThoughT ExperimenTs » Sat Apr 02, 2005 11:12 am
1990 Toyota Celica
ThoughT ExperimenTs
Postby ThoughT ExperimenTs » Sat Apr 02, 2005 11:37 am
Ok it's working fine now, when it cools down again i'll let it run without the cap on so it can empty out a little more air and then i can add more coolent (because it will have like 90& water in there)
Thanks a lot vvega and everyone else for the help and advice :)
ThoughT ExperimenTs
Postby edwagon » Sat Apr 02, 2005 11:45 pm
make sure the bottom hose gets hot!!! that is how you check for thermostat opening, means that water is being circulated thru rad and out the bottom. The car isn't ok to drive until you are positive that the thermostat has opened and the bottom hose is hot to the touch. try rempving a heater hose or another hose near top of engine and making sure you have coolant at both side of the opening. you may need to get the engine hot, then let it cool down and let it bleed itself
edwagon
Postby ThoughT ExperimenTs » Sun Apr 03, 2005 10:31 am
Yea the bottem hose went hot, the engine temp stayed at half way and the fan came on after a while. It's just because when I let it run without the cap it spilt out all the coolent :oops:
It's alright now, thanks :)
ThoughT ExperimenTs
Postby Rob » Mon Apr 04, 2005 9:05 pm
The reason that your car gets an airlock is beacause the air does not like to go down in the galleries. All you need to do is put a funnel in the radiator cap so it is higher than the engine and put the fan on high so the water can pass through as this is normallywhere the airlock is hanging out.
Also you can blled at the bottom of the throttle body if injected :wink:
1990 ST185H - project
1996 VS Acclaim wagon
Rob
Postby ThoughT ExperimenTs » Mon Apr 04, 2005 10:16 pm
I actually have a feeling the headgasket has blown.
ThoughT ExperimenTs
Postby [V8ROLA] » Wed Apr 06, 2005 7:15 pm
top up the radiator, have car on angle so cap is higher than motor or as stated above (funnel), run motor and top up till its full, HAVE heater on hot setting you dont need the fans on as this will cause it to take longer to heat the water, just leave it running and kepping an eye on water level just top it up as needed and the thermostat should open just as the fans kick on.
and yes make sure both radiator hoses are hot.
also another way to rid air locks is to fill the resivour to the top and find a step hill and drive up it :P
and re-check the resivour tank when you get back and see if it used any water.
1995 ducati 900ss with a 2001 fuel injected motor, ramflow intake, open pipes, polished wheels and afew other mods.
more to come ;)
1983 RX7 series 2 with small block chevy.
http://photos.data.net.nz/?dir=V6ROLA%2 ... sion%20%2F
[V8ROLA]
Real Life Mechanic
Users browsing this forum: Bing [Bot] and 28 guests
