Shift selector light not lighting up drive (caldina)
Postby Four_Seven » Sun Apr 03, 2005 2:03 pm
Dad's got a 1.75L auto caldina that doesn't light up the drive light on the dash anymore. It's a 1999 (AT211? - that's the chassis code on the firewall) with a 7A-FE engine.
What would cause this and how could we fix it?
Four_Seven
Postby Damo Monster » Sun Apr 03, 2005 9:56 pm
bulb in the dash would have blown... that would be my best guess. you'll need to pull it out and replace it... but if you arent sure what your doing... then don't cause there is quite often a lot of wiring behind there and sometimes its easy to get them out but a bastard to put back in...
Damo Monster
Postby Four_Seven » Mon Apr 04, 2005 1:31 am
Aren't they just LED's though? which i'm sure are very difficult to destroy if used in the correct manner.... or could an LED blow too in a situation like this?
Four_Seven
Postby matt dunn » Mon Apr 04, 2005 6:40 pm
Four_Seven wrote:Aren't they just LED's though? which i'm sure are very difficult to destroy if used in the correct manner.... or could an LED blow too in a situation like this?
Not normally LED's in the dash, and so they blow bulbs occasionly.
Matt
Postby t0ms » Mon Apr 04, 2005 8:00 pm
unless it is the new shape caldina (the gt-four shape) it will have bulbs behind the gauge cluster
the new caldina shape run LED lights and a full intergrated gauge thingy its nuts, got to play with one the other day
tom
t0ms
Postby Four_Seven » Mon Apr 04, 2005 9:35 pm
t0ms wrote:unless it is the new shape caldina (the gt-four shape) it will have bulbs behind the gauge cluster
tom
Could be, it's got round rear lights..
Four_Seven
Postby t0ms » Mon Apr 04, 2005 10:24 pm
nah i mean new as in
not face lift of the old shape
tom
t0ms
Postby Four_Seven » Mon Apr 04, 2005 10:56 pm
Wow that is cool, but yeah it's a facelift of the old shape then. bulb shopping it is i guess.... thanks
Four_Seven
Postby Mr Revhead » Mon Apr 04, 2005 11:55 pm
toyota p/n 99132-12034 we sell a few......
Postby Inane » Tue Apr 05, 2005 9:37 am
also there is a bit of an issue where the dashes look like arent lighting up properly,
undo the dash pull it forward, then click it in again and hey presto it might work... (did for me, although you may as well check the bulb at the same time)
Inane
Users browsing this forum: Google [Bot] and 50 guests
