Gearbox or diff whine
Postby Voodoo » Sun Apr 03, 2005 5:02 pm
hey just wondering if there is audible ways of telling wether a whine is gearbox or diff? ive notice a whine in the driveline since d1 r1 , its sounds as if its coming from the back of the gearbox, but maybe it could be the diff instead, bit of a noob when it comes to this sort of thing :oops: , any quick and easy way of telling? this whine on comes on when accelerating, and goes away when lifting of throttle, but that prob wouldnt tell me much?
Voodoo
Postby dohca » Sun Apr 03, 2005 5:33 pm
i know my old old t50 had a horrible whine in 5th gear, you could feel it through the gear stick
a diff noise generally comes from the rear of the car... :D
prehaps get a mate to sit in the boot and see if they can hear the noise in the rear? i have also noticed on the skyline that the noise from the diff tends to resinate louder than one from the gearbox, prehaps it has something to do with the way its mounted etc
dohca
Postby Voodoo » Sun Apr 03, 2005 5:37 pm
yeah its just that this seems to come from back of gearbox, front of diff area, but is abit to tell from drivers seat, plus the lack of rear seat/carpet might tend to push the noise futher back,
this is more 3rd/4th gear where its the loudest
Voodoo
Postby dohca » Sun Apr 03, 2005 5:39 pm
may be drive shaft carrier bearing?
dohca
Postby Voodoo » Sun Apr 03, 2005 5:41 pm
hmmm, maybe, ill get it checked out, just thought id ask
Voodoo
Postby Jebus » Sun Apr 03, 2005 6:41 pm
When does it whine? A worn diff will whine when it has low stress on it at lowish revs, about 1/4 throttle.
Thats what all mine sound like, then when you back off they make a clicking noise then they go bang.
If it does any of that its probaly your diff.
Jebus
Postby Voodoo » Sun Apr 03, 2005 8:16 pm
nar, no clicking or banging, its a lsd unit by the way if thats anything
its prob the gearbox then, it does sound alot like the k50 i had in it that whined, but it just sounded abit futher back thats all
Voodoo
Postby Rob » Mon Apr 04, 2005 8:48 pm
If the whine is constant as you speed up then it will be your diff, but if it comes and goes as you change into different gears then it will be in the box.
Then again if it is whining with the clutch engaged then it will be your clutch release bearing
1990 ST185H - project
1996 VS Acclaim wagon
Rob
