TWSTD wrote:interresting - how did you test this? I would be interrested to know of anyone running a custom intake manifold on the gen4 engine also - particularly one with shorter runners!
TWSTD wrote:fair enough - but thats not really simulating the intake manifold conditions when running boost is it - as you have no valves closing to cause pressure to build up in the manifold. If you have a constant pressure in the intake manifold it will act differently to the bench test that you did as i suspect feed air more evenly into each cylinder.
vvega wrote:because they run hotter.........
#1 and #4 only have one side exposed to another cylander wall wereas #3 and #2 have heat producing cylanders on both sides
the cylanders are not seperated by water......
this is very simple stuff and is covered in the first year of uni under the topic of thermodynamics
your flowbench results are a waste of time...........
listen to what peole say and you might lern
first stop will be new ecu
nextintercooling will become a issue
the injectors will be next
the pump next
then looking into a better rail design
at this stage the turbo will have run out of puff...
once you have spent the best part of 15-20,000 getting to here
a look at a new intake plenum to better balance the 5-700 hp you now have of air supply will be required
vvega wrote:
if you really have that much of a concern run quads and a big plenum and get on with it
Motec's injection maps for 3SGTE 3rd gen ( center top feed int.man ) are 3,5% richer for #2 and 2% richer for #3 cylinders....
why ?
Wolf_Tm250 wrote:Motec's injection maps for 3SGTE 3rd gen ( center top feed int.man ) are 3,5% richer for #2 and 2% richer for #3 cylinders....
why ?
fivebob wrote:This subject is so complicated I’m not even going to attempt to fully explain it
Uneven flow in a manifold tested under steady state conditions is not a good indicator of flow into the cylinders. Your original test with an air gun is next to useless as that relies on the air changing direction of it's own accord, which of course it can't do until it hits a surface an bounces off it, which is nothing like what is going on when the engine is running.
why ?
Depends on how the engine was tuned, if it was tuned with individual Lambda & EGT sensors for each cylinder, then it may be correct.
