4k Hesitation/Missing
Postby 1goodidea » Wed Apr 06, 2005 7:58 pm
Hey, i've just swaped in a 4k in place of my 2k motor in my starlet
Heres the setup
4k motor
4speed gearbox
2k carb
Problem
Car isn't idling smoothly - the motor is abit shaky
Then when you do drive it the motor hesitates at low revs
what would course this?
I have pulled plugs out and cleaned them, no difference
THEN
swaped plugs and leads for the plugs and leads that i had on my 2k motor which ran very smoothly still no change.
any thoughts?
1goodidea
Postby fuel » Wed Apr 06, 2005 8:19 pm
Could be the 2K carb (which is designed for a 1000cc motor), is having problems delivering air/fuel to the 1300cc 4K. Are you sure it's ignition related? Could be distributor cap/rotor/points (if it has them) etc.
LOUD NOISES!!!
fuel
Postby 1goodidea » Wed Apr 06, 2005 8:30 pm
I heard the 2k and 4k carbs are the same?
I've done the swap before and it ran absolutely fine with the 2k carb?
1goodidea
Postby wde_bdy » Wed Apr 06, 2005 8:33 pm
There are different size jets in the carb.
Callum
wde_bdy
Postby EVL20V » Wed Apr 06, 2005 8:42 pm
had similar problem putting diff. carb in 2 a corolla. a possible fix could be installing a monsta tach.. :lol:
EVL20V
Postby 1goodidea » Thu Apr 07, 2005 9:11 am
anyone else with some idea?
1goodidea
Users browsing this forum: Bing [Bot] and 7 guests
