Rotors machining
Rotors machining
Postby Akane » Fri Apr 08, 2005 2:30 pm
Is there any places that does rotor machineing? pitstop wants $120 for the front 2 rotors only.
Thanks
Postby Dr-X » Fri Apr 08, 2005 2:53 pm
Call a mobile guy - if I remember correctly, the going rate in Tauranga is about $30/rotor???
Dr-X
Postby Dell'Orto » Fri Apr 08, 2005 4:14 pm
If its on your MR2, you may need to replace them, they've only got about 1mm of tolerance each side.
Postby Akane » Fri Apr 08, 2005 5:05 pm
gayness :(
Postby Jebus » Fri Apr 08, 2005 5:27 pm
If you take the rotors out yourself, its about $40 a pair at pit stop. Theres a certain amount of tolerance as to how much they can remove from the disc, they cant be machined if theyre too worn or the scrathes are too deep.
Jebus
Postby starlet drifter » Fri Apr 08, 2005 5:28 pm
Pitstop is RAPING you if they're charging that!!!! there is no reason why it should cost that much... holy crap!
Shouldnt cost more than $30 a rotor, if its more, you're getting reamed. BNT and such places do it for that...
$120 8O
mmm 4age kp starlet :D
starlet drifter
Postby pervert » Fri Apr 08, 2005 5:31 pm
A 24 pack or a tinny should be all it costs... :D
pervert
Postby toyonut » Fri Apr 08, 2005 5:44 pm
take them out yourself and drop them into a machining shop that has a lathe. They should be able to do it for cheaper than that, unless the rotors are stuffed beyond machinable tolerance.
toyonut
Postby Akane » Fri Apr 08, 2005 7:10 pm
well the rotors have hotspots so i've been told, a lot of shake at high speed braking. So I might have to get new rotors. Maybe they'll go good with my TRD brake pads?
Postby ps165 » Fri Apr 08, 2005 7:44 pm
if the have hot spot ur best to get new ones, at cost price they are about 40 a piece.
ps165
Postby Akane » Fri Apr 08, 2005 8:21 pm
Where can I get brake rotors that cheap?
Postby Dell'Orto » Fri Apr 08, 2005 10:56 pm
Through a mate who works at BNT/Repco etc ;)
DBA slotted rotors are available ex Aussie, though there are some x drilled and slotted ones in the country...retail is like $400 per rotor though :?
Postby Mr Revhead » Fri Apr 08, 2005 11:33 pm
nah f that, i can do DBA ones for cheaper than that!!!
new genuine ones are only $144rrp+gst.....
Postby Akane » Fri Apr 08, 2005 11:37 pm
Hmm I'm confused, can anyone tell me where I can get replacement rotors for resonable price? Not "a mate's hookup" coz that'll be your hookup that I don't have access to.
Postby Mr Revhead » Fri Apr 08, 2005 11:45 pm
email me your full model and frame numbers
Postby Zero_Cool » Sat Apr 09, 2005 1:54 am
wow theres a place in welly that does it for $20 each but prob best replace em as they are usally worn down close to the minimum level any machining and it will weaken it to much
City -> Corolla -> Integra -> Celica -> Impreza -> ?
Zero_Cool
Postby Si » Sat Apr 09, 2005 10:31 pm
every 1mm you take off adds about 2m to your stopping distance at 50kmh (or so i remember)
take 1mm off each side and that makes 2mm or 4 meters.......
New rotors = win.
Current: , '96 SubaruImpreza
Si
Postby Ae92typeX » Sun Apr 10, 2005 10:49 am
Si wrote:every 1mm you take off adds about 2m to your stopping distance at 50kmh (or so i remember)
New rotors = win.
Although Im not trying to argue this, and also say go for new rotors...how is this the case?
I mean, you machine it down 1mm of whatever, once you have bled the brakes and stopped once, they are still the same didtance from the disc as they would be with new rotors!...not an extra 1mm away.
Ae92typeX
Postby wde_bdy » Sun Apr 10, 2005 11:12 am
New rotors = win.
Rubbish, skimming would ONLY impact heat handling. On your first hard stop it would have exactly ZERO IMPACT on stopping distances. Thats like saying vented rotors will stop your car faster. They don't they simply maintain the ability to stop for longer before overheating.
Callum
wde_bdy
Postby NZ_AE86 » Sun Apr 10, 2005 12:55 pm
New rotors = win.
What a crock of shit! They may fade quicker but you will never notice it! :roll: :lol:
NZ_AE86
