fxgt q need urgent help
Postby SIDE_FX » Fri Apr 08, 2005 3:56 pm
hey jump in the rolla yesterday turned it on then switcheed the lights on nd only the parklights come on, but the blue high beam light came on but only at half brightness, u click the arm forward nd nothing happens but pull it back the high beams come on but a bit delayed and the high beam light goes full brightness, wtf is goin on checked bulbs, fuses that i know off and the battery but they all sweet this happened to any one before ? but yeaha as u can see need the help quite urgently cant drive anywher at night cheers
SIDE_FX
Postby Caveman » Fri Apr 08, 2005 4:45 pm
Happened to me
You need to take off all the trim around the steering wheel and find the switch for your headlights. Then just clean the contacts.
AW11 Track Toy
Formerly known as 1998
Caveman
Postby SIDE_FX » Sat Apr 09, 2005 4:42 pm
SIDE_FX
Postby SIDE_FX » Sat Apr 09, 2005 9:22 pm
any other options i cleaned the points nd nothin changed
SIDE_FX
Postby Caveman » Sat Apr 09, 2005 11:20 pm
Have you checked the relays are switching properly?
AW11 Track Toy
Caveman
Postby SIDE_FX » Tue Apr 12, 2005 11:40 pm
how did u get to the point i cant get the arm assembly over the steerin shaft also when u pull the highs on the relay makes a noise i replaced it tod but no change
SIDE_FX
