st183 and 3sgte questions
Postby Liloss » Sat Apr 09, 2005 3:06 pm
well i just got my car back after almost a month and well it blew a brand new HG on the way home. Very pisst to put it politly. Also it has a massive knock in the sump area and misses like mad on number 3 cylinder. My temper boiled over and decided enough is enough. my GF has offered to buy me an engine, which happens to be a 3sgte gen 1.
Come with loom ecu engine and gearbox. Pretty keen to take her offer as the 3sge is really toasted. Question is though, how will i get on running the 3sgte ECU with the 4WS and the "Sport mode" and "revs 2ws" stuff? Will some crafty wiring be needed or will i simply just loose them?
the 3sgte and stuff came from a ST165. Any ideas?
can i use the st165 loom or do i need a st185 one? and wi the gen 1 ECU work with a st185 loom? im only new to celicas so thats why the long, dumb and confusing questions.
~~Liloss~~
Liloss
Postby Malcolm » Sat Apr 09, 2005 4:36 pm
you would be way better off getting an engine from an st185, then it is practically a plug + play conversion. the 4ws controls are independant of the engine ecu, so shouldn't be any problems there.
Postby Liloss » Sat Apr 09, 2005 4:53 pm
would a st165 3sgte and a st185 loom/ecu work?or be more "plug and play?"
~~Liloss~~
Liloss
Postby Malcolm » Sat Apr 09, 2005 5:14 pm
yeah I think you can swap looms, although you might need to change some plugs, also you need to source some parts like a map sensor
3s
Postby KE20 » Mon Apr 11, 2005 11:23 am
put the st165 engine in your car, but to use your 185 loom youll have to have to swap a few things like the injectors, but the rest should be the same. you may want to swap the head as the 185 head is better than the 165.
KE20
