subie racer wrote:and if a person with basic mechanical knowledge like me would know how to put it in??
i got told the diff in it now was a 5 speed lock diff.
Subieracer wrote:and if a person with basic mechanical knowledge like me would know how to put it in??
Dr-X wrote:subie racer wrote:and if a person with basic mechanical knowledge like me would know how to put it in??
5 speed lock diff? I'm not sure what you mean by 5 speed.
Does the car still go? Does it make the noises only at high speed, only at low speed, or always? Does it change/stop/increase when you turn?
Lock diffs will eventually blow - there's not really a lot you can do about that. They're not designed for that kind of strain (not to mention your axles and various other bits and pieces). If you have the right equipment, and you're keen enough, you should be able to change it yourself - it's not a huge job.
RS13 wrote:Subieracer wrote:and if a person with basic mechanical knowledge like me would know how to put it in??
I was just answering that question.
Dr-X wrote:I disagree - on a locker it's FAR more likely he's blown the head - the only reason the crownwheel and pinion would be damaged would be if he's got some bits of diff head in there.
Take it for a spin and see how far you get - you'll tell pretty quick what's wrong. May just be an axel (which is most likely with a lock diff, imho).
