TRD Metal Head Gaskit
Postby GTSMR2TURBO » Mon Apr 11, 2005 10:27 pm
Whats the major benefits of these ???
Current Ride - 1993 GTS MR2 (K&n pod, HKS bov, Toms Kit)
GTSMR2TURBO
Postby Distrb » Mon Apr 11, 2005 10:49 pm
depending on the thickness of the head gasket used, it will lower (thicker) or raise (thinner) the compression ratio of your engine
Distrb
Regular Poster
Postby Mr Revhead » Mon Apr 11, 2005 11:19 pm
they are thinner than stock, increasing compression slightly.
made of metal so stronger
Postby dotdog » Tue Apr 12, 2005 5:59 pm
If you put one of these in your car i will bash you, and putting that bigger turbo on you dont want to raise compression
Daily Ride - 00 Subaru WRX STi RA 12.7@113
Project Car- 89 Toyota Starlet Turbo S 95.1kws
Ex Ride - 85 Toyota Starlet Si with 4efte, 1990 Nissan Pulsar GTiR 150Kw/atw, 97 Toyota Levin BZR
My Profile: http://toyspeed.blakjak.net/profiles/profile.php?id=589
dotdog
Postby Mr Revhead » Tue Apr 12, 2005 6:18 pm
yeah if your raising boost etc itll be best to do some research before doing it
Postby fivebob » Wed Apr 13, 2005 11:31 am
dotdog wrote:If you put one of these in your car i will bash you, and putting that bigger turbo on you dont want to raise compression
Maybe so, but an decrease in squish can reduce the potential for detonation by far more than the minor increase in compression would increase it. You shouldn't just look at higher compression as the sole factor in deciding the thickness of a head gasket.
