Speed Sensor Swap
Speed Sensor Swap
Postby Corona » Wed Apr 13, 2005 11:21 pm
Is it posable to take the electronic speed sensor from the A241E Auto Transmission that I have now, and use it on the Manual that I am putting in my car?
I would assume not, but need to ask in hope.
Neil
Just remember: The glass is neither half full nor half empty, it is merely the wrong size
Corona
Postby Corona » Sat Apr 16, 2005 10:18 am
Anybody? :(
Corona
Postby sergei » Sat Apr 16, 2005 11:21 pm
might, how about that, the actual sensor probably will fit...
Postby Ae92typeX » Sun Apr 17, 2005 3:53 pm
Yea, might...
I dont know the specific details of the boxes, but if the manual one never had a speed sensor then you will want the ring gear off the auto trans main shaft. it may or maynot require welding onto the manual shaft and then a hole made to put the sensor through.
I know this mod has been done and works on w5# boxes, so in theory it would work for you, just do a little measuring of shaft size etc.
Ae92typeX
